Old 07-27-2018, 11:30 PM   #1
tuff enuff
disc brakes and drop spindles????
I have a 66 c10 , the PO did a disc brake conversion on it. I am wanting to install drop spindles , most of the drop spindles require converting to 71-72 disc brakes or equivalent. Am I in the clear or do I have convert ?
THANKS
tuff enuff is offline   Reply With Quote
Old 07-28-2018, 03:05 PM   #2
AZ 67 C10
AZ 67 C10's Avatar
Re: disc brakes and drop spindles????
I had to buy a bracket to bolt my disc brakes up to my drop spindles. PO also did a disc brake conversion, although I replaced it all with new.
I'd get the spindles and see if they bolt up. If not you can get some different mounting brackets likely.
AZ 67 C10 is offline   Reply With Quote
Old 07-28-2018, 10:05 PM   #3
tuff enuff
Thanks AZ
I guess I'm going to pull the trigger. I think I'm going to contact belltech and see what the say or if they sell a bracket.
Old 07-31-2018, 07:07 AM   #4
PGSigns
PGSigns's Avatar
First thing to do is identify what was used to do the disc brake conversion. Many of these trucks with out a drop have the 73 to 87 stuff in them. They are the easy ones to find. They also could have 1" or 1 1/4" rotors. So before you order anything post some pictures and lest make sure you are on the right path.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
