Old 08-21-2002, 12:56 PM   #1
Huck
Huck's Avatar
Primer over POR15 WRINKLED!
Jamie_72 sent me a note re. putting primer over some POR15 and it got all wrinkled. Can anyone with experience on this help him out with a follow-on to this Thread? When I have used POR15, it was usually in a spot that I didn't care if the cover paint wrinkled as long as it sealed the rust! Thanks---Huck
Huck is offline   Reply With Quote
Old 08-21-2002, 01:09 PM   #2
vfrdude
vfrdude's Avatar
From the POR-15 web store:
PRIMING OVER POR-15:
Use POR-15 Tie-Coat Primer after POR-15 is dry, following directions on can. Tie-Coat Primer may be sprayed or brushed in multiple coats if desired. Sands to a perfect finish.
This information should have been included with the product...
Rudy Fierros
'95 Honda VFR750F
Used to have a '71 Chevy Stepside, Guards Red, Lowered 4" rear, 3" front, White Oak bed wood, 700R4 w/373 gears until some low life stole it!
vfrdude is offline   Reply With Quote
Old 08-21-2002, 05:37 PM   #3
jamie72
jamie72's Avatar
Thumbs down
i used the tie coat primer over the por-15,just like it said,it was completly dry shot primer over it,and it just crumbled up....the places with no por-15 on it look great
can i just sand it off and ruff up the por-15 and shoot it again?????
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 08-21-2002, 06:10 PM   #4
vfrdude
vfrdude's Avatar
I don't think you need to use another primer over the tie-coat..
If I were you, I would either call or send a note to the POR-15 people...
http://porstore.com/contact.htm
Rudy Fierros
'95 Honda VFR750F
Old 08-21-2002, 10:07 PM   #5
jamie72
jamie72's Avatar
Question
well i e-mailed the por-15 people,we`ll see what they say,
i used another primer because the tie coat is light,and the red oxide primer is dark,didn1t know if it would change the color of the paint...
thanks for the replies
jamie72
member #807
www.antlertalk.com
