Old 05-15-2012, 12:36 PM   #1
Mrcustom
Question starter or Ignition trouble
I just finished hooking everything up in my 57 pickup brand new crate 350 motor, brand new TH 350 Transmission, Radiator, well you get my point. So I start it up sounds great 75 lb oil pressure 14.7 amps 175º .Sounds good now the problem is if I turn the key to off quick all the way it sounds like the starter is engaging but if I only turn the key half way off, I guess it would be the Accessory. The motor shuts off fine no problem.Very annoying and it kinds of scares you when you don't expect it. Any Ideas? O yea with the old 400 that was in there I didn't have this problem. I did though have the problem where I had to let go of key to get it to start. Hope you can understand my babbling.
Jim
Mrcustom is offline   Reply With Quote
Old 05-15-2012, 01:45 PM   #2
55Cameo
55Cameo's Avatar
Re: starter or Ignition trouble
Sounds like its in the ignition wiring or the switch itself. Have you checked those hook up's yet?
Build thread:55 Cameo R!! http://67-72chevytrucks.com/vboard/s...d.php?t=519851
55Cameo is offline   Reply With Quote
Old 05-15-2012, 01:56 PM   #3
OrrieG
OrrieG's Avatar
Original starter switch or new? I have had shorts where the start circuit would not work, but it would try and fire when I released it and it jumped back to run. Sounds like a switch issue, usually not repairable.
Old 05-15-2012, 03:07 PM   #4
Mrcustom
The starter is a brand new high torque and the switch itself I believe It came with truck. Does anyone know where I can get a good pic of Ignition switch wiring. I really don't know how to check if an ignition switch is bad, does anyone know this. Thanks
Old 05-16-2012, 11:42 AM   #5
mr48chev
mr48chev's Avatar
stock switch, universal switch or one on the column in a late model column?
If it is under the dash check for wires crossing each other and making contact where they shouldn't.
