I must be dumb, but here's a question
Do I have to remove the rear axles to do brakes on the 74 C20? I was told by some dude that I did to service the back brakes. I need to put in new brake cylenders and adjusters. Thanks!
kev |
![]() Join Date: Oct 2006
Re: I must be dumb, but here's a question
Yes. Once you remove the 8 bolts on the flange,smack it with a hammer and the axle will pop out. Then you'll see the large retainers and nuts that have to come off to get to the brakes. Good Luck.
-Lance
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
Is it a ***** to get the axles back in?
Not really just slide them in the wiggle a bit and the splines will slip into place.
2006 Silverado Crew Cab 1500 4x4 5.3L automatic 1986 M1008 CUCV 6.2L Detroit Diesel TH400 4.56 Detroit Locker rear NP208 1973 K20 "Silverado" 350ci, HEI, TH350, NP203 with 2wd conversion, A/C, power windows,tilt wheel, dual tanks. My '73ish K20 thread My 5yo son claims it as his. 1987 V20 Custom Deluxe 350 TH400 NP208 "farm truck" getting parted out. 2016 Nissan Altima grocery getter/commuter |
Put a pan or small bucket under the end of the axle it will most likely drip a bit of gear oil out. It's pretty straight forward just bulkier/heavier than most drum brakes.
does anyone know what i can do to my 305 to get more power out of it?
#8 | |
not on a thread about rear drum brakes. ![]()
