72 400 Transmission
Anyone know how to read the plate on the side of this 400 I got other day. reads 72-CJ 428 and the Trans SN from what I found 72 truck year and 396 BB does this sound correct or ? Thanks
Re: 72 400 Transmission
any trans guys here ??
![]() Join Date: Oct 2009
There were no 396 engines in 72 (so am not sure the SN lookup you used is reliable), however, TH400 would be the correct trans for a 72 (2WD only) that came with a 402.
TH400 SN is usually stamped on driver side just above the pan rail - any additional info there? |
Who Changed This?
![]() Join Date: Jan 2013
CJ-428 looks like F*%d nomenclature.
The CJ stands for chevy truck or Suburban 72 was year I guess the one I used shows 396 in 72 for 3/4 ton suburban I will post the site when I get home what site you all using to decode.?
I think the 428 is year code?
![]() Join Date: May 2010
There is a lot of discussion about decoding engines and transmissions in these threads including discussion about my TH400.
http://67-72chevytrucks.com/vboard/s...hlight=69t+328 http://67-72chevytrucks.com/vboard/s...69t+328&page=3 Do you have a picture of the tag that is riveted to your transmission? I believe the J in the code (CJ) you supplied indicates it is for a big block. |
