PROJECT 7DEUCE
![]() Join Date: Dec 2002
Need measurement on drive shaft..
I have finally got the 454 th400 combo in my truck and running but need a new (shorter)drive shadft from the tranny yoke to the carrier bearing waht it the best way to measure for this or does someone have a measurement from theres?? My motor is in the front mount holes and the tranny is a short shaft..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
PROJECT 7DEUCE
Re: Need measurement on drive shaft..
I am useing the 2 pc shaft... Was not sure on a 0ne pc shaft
Fabricate till you "puke"
The diff from a 350 T (shortie), & the 400t short , is 11/16 ". The 400 being the longer of the 2. Assuming that you havent moved eng position (swapped sb to BB), 11/16" should work as the shortening figure on the shaft. if you have moved stands/swapped things.....the best way is "shove a bare slipyolk into the trans till it bottoms, then pull it back 3/4 min, to 1" max. measure from the center of the front U joint caps , to the centerline of the bolt holes on the carrier bearing". this will give you the lenght of the front 1/2 of the shaft, that the D line shop can work with
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... Last edited by crazy longhorn; 12-24-2005 at 03:23 PM. |
PROJECT 7DEUCE
Thanks crazy!!!!
A guy with a truck
Mine was 56" center to center with the short tail 400. 53" now with the 700r4...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
