Air Vent Block Off
I've been doing some searching but haven't stumbled upon a block off plate for the kick panel air vents on our trucks.
Does anybody know of a vendor that makes them? |
Moderator
![]() ![]() Join Date: Aug 2011
Re: Air Vent Block Off
I have never seen them aftermarket.
16 Gauge sheet metal from home depot and a pair of sheers. A drill for the holes. Use the original unit for a pattern.
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 10-06-2017 at 02:02 PM. |
![]() Join Date: Jul 2014
Vintage Air has them. I blocked off both of the kick panel vents when I put the VA in my truck.
1966 K20 flatbed build thread - http://www.67-72chevytrucks.com/vboa...d.php?t=768827 62 C20 build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=703583 |
Thanks for the responses guys! I'll check into the ones from Vintage Air, otherwise I'll make some!
Moderator
Once you cut them with sheers you take a ball peen and hammer around the edges to flatten it. Then use a Makita 4 inch with a wheel or flapper to smooth out the edges. Prime and paint the backside at least before install.
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
