What are these wires for ? 72 GMC
Help
Can anyone identify what these wires and plugs would be for? 72 gMC with 307 and 4 speed floor shift. It now has a 305 and is not using these anymore. They are all on the same harness passenger side are near the firewall. One green wire on its own with a plug and loomed One semi thick red (power I assume) with a plug Then one 3 wire plug with a blue, green with a white stripe , and brown with a white stripe. |
#2 | |
The Older Generation
Re: What are these wires for ? 72 GMC
The Green one would be for the temp gauge sender (should be in the head by #1 spark plug) The other ones look like Alternator wiring. LockDoc
#3 | |
As for the other plugs the red and the 3 wire plug yes a previous alternator connection sounds right. |
#4 | |
Yes, for the temp gauge. Some of the later engines may have had a sender in the T-stat housing but I think the '72 was still in the drivers side head. Not sure about the Canadian models though. There is a port by the #8 plug also but you very seldom see a temp sender in that location. Do you have a temp sender in the drivers side head by #1 plug? LockDoc
#5 | |
![]() Join Date: Mar 2003
Looks to me like an old NOx system wiring that cut out vacuum to the dist until you shifted into 4th gear. Used to be a solenoid bolted to the intake and a relay on the firewall. dark green wire does look like the temp wire with the insulation and the broken metal bracket. Looks like it may have been rerouted at some point
Wow I just posted this link about 20 minutes ago for something else. You can look up the wire colors yourself here:
http://67-72chevytrucks.com/vboard/s...d.php?t=558016
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks... |
