Backfiring
My truck is starting up and it hesitats when starting. Once it goes it runs great above 2500 rpms but bellow that it starts spitting and sputtering and backfires. Any ideas? Also the engine will not idle if you let off the gas the engine dies out
![]() Join Date: Oct 2006
Re: Backfiring
Check the timing. Is it backfiring through the carb or exhaust?
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
Re: Backfiring
through the carb. I cant even get the truck to idle to time it.
never finish start another
Re: Backfiring
Pull plug wires off one at a time. Could be an intake valve?
Re: Backfiring
vaccuuum leaak
Re: Backfiring
1. I'd check timing, by hand if not by light.
2. I'd consider the age/condition of the carb. Is this an existing problem that got worse, or a new problem on a newer setup?
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! ![]() 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! ![]() |
Re: Backfiring
Carb flooding. Do you see black smoke?
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
Re: Backfiring
Plug wires crossed?
Tim |
Re: Backfiring
I would check timing, Also inspect the cap and rotor for cracks or excessive wear. Check and make sure your idle is right, You can also Try retarding your timing by hand & Ear.
You can also pull your plugs to help let you know if you're running a little too rich or lean (Grey / Ash color Lean, Black or sometimes gasoline smell is Rich, Tan is just right), and make sure your Firing order is right (more then likely it is but just in case.) Float Level Too High? That should help, Need more info on the truck to get a better idea on whats going on. Sounds like the timing is too far advanced though and the idle might be off a bit, More info would help though. ![]() Last edited by Pumped 68; 07-17-2007 at 07:25 AM. |
Re: Backfiring
Sound like one of a few things. The timing is too far advanced,the chain is streched, cam is going flat, or the wires are in the wrong places. Firing order is 1-8-4-3-6-5-7-2 clockwise. Good Luck. Keep us posted.
-Lance
Re: Backfiring
Backfireing through the carb is a lean condition or timing is late. Advance the timing not retard it.
Make sure all ignition parts are good and carb accelerator pump is working. I would start there first.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
Re: Backfiring
Wow, what was I thinking!? I was meaning retarded and put it adavanced! Now I am retarded! Sorry!
Re: Backfiring
Agreed that job 1 is timing. If you can't get the truck to idle, you can statically set the timing by positioning the engine at 8-12 degrees BTDC and pointing the rotor exactly at the #1 tower.
If you can't get it to idle, I'd also take a hard look for vacuum leaks. |
Re: Backfiring
Well I advanced the distributor to get the best time i could get with just sound. Now its no longer back firing. I also think I found a vaccum leak there are 2 black gaskets on the carburator, and I sprayed starter fluid and it reved up when i sprayed it along the gaskets. So I went to autozone and they dont have any gaskets for it saying it was part of a rebuild kit. Dont know if there is any truth to this. Do any of you guys know and if so where do you get them at. I belive I have quadrajet carb. Thanks for any help.
#15 |
Re: Backfiring
Just a reminder that your timing is almost certainly too far advanced at this point.
They're likely right about the gaskets; the rebuild kit should be fairly cheap... |
#16 |
Re: Backfiring
after all that i have seen it sounds like your timing is a full 180 out and a new set of plugs is recomended. you should be able to tell if u have a quadrajet, its an almost perfect square and looks like no other carb out there.
70 Chevy C-10 short step 250/3 on the tree Owned: 71 longbed Cheyenne 70 swb |
#17 |
Re: Backfiring
I can't see how it's 180 out if it's running smooth above 2500 RPM...
#18 |
Re: Backfiring
Well here is pictures of the carb that I have. Maybe someone can help with me with what kind it is. I am not sure I am new and dumb to all of this.
#19 | |
OLD FART(I GUESS)
Re: Backfiring
1967 Shorty Stepside 1967 Shorty Fleet 1967 3/4 Fleet LB 1972 LB Fleet ....RAP IS TO MUSIC WHAT ETCH A SKETCH IS TO ART.... |
#20 |
Re: Backfiring
anybody know where i could get a rebuild for it?
#21 | |
Re: Backfiring
#22 |
Re: Backfiring
Good eye jhow66. That will make a lean condition for sure.
#23 |
Re: Backfiring
Check for sure that if you put the correct gasket under that carb. I rebuilt a Quadra years ago and used one of the 15 gaskets in the kit that was wrong!!! Changed it and it cured it. Spray carb cleaner around the bottom of carb at idle and if it smooths out, you have a leak.
#24 |
Re: Backfiring
Sounds like a vacuum leak to me.
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe |
#25 |
![]() Join Date: Dec 2006
Re: Backfiring
Looking at that picture, the first thing I notice is that the clamp is missing from the PCV hose where it fits on the carb.That is the larger black hose that goes into the front center of the carb and from there to the PVC valve in the left valve cover. Chech those connections and add a clamp. If the hose is hardened where it fits,replace it! Pull the PVC valve out and shake it to see if it "rattles" (it should,if not REPLACE IT!). Spraying starer fluid around the carb will always cause an increase in RPM because it will be sucked into the carb,it's kind of a tricky test. If you had the air cleaner on and the gaskets under that were good,then the test would be more meaningful as the spray would be less likely to find it's way into the air-cleaner intake.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. Last edited by WorkinLonghorn; 07-17-2007 at 10:26 PM. |
