![]() Join Date: Feb 2019
1970 C10 Steering Column missing parts
Slowly but surely putting this truck together I bought in pieces. Replacing cracked turn signal switch now and discovered I am missing 2 "washers" that appear to go between the shifter cup and the switch housing. It does have the plastic one below the shifter cup.
My question is does anyone have a picture of what those look like ? Does anyone know if they can be bought somewhere ? Or, is this going to be a junkyard type thing ? Last edited by Danman09; 02-24-2021 at 10:31 PM. |
#2 | |
The Older Generation
Re: 1970 C10 Steering Column missing parts
See if this will help. Post #14 if it doesn't come up to it. http://67-72chevytrucks.com/vboard/s....php?p=4800898 I don't have any more of them and as far as I know they are not reproduced. Maybe someone has started making them though. LockDoc
#39 and #40 are what I am missing. Thanks . Now I just have to find someone who has some.
If a 70 Monte Carlo non tilt column uses the same washers, I should have them in a steering column I pulled out of a 70 Monte Carlo parts car that I had. The column isn't going to be used in my 72 Monte Carlo as it has a factory tilt column.
72 Chevy Cheyenne K10 4x4 LWB, 4" lift kit, 350/350/NP205, rebuild in progress. |
If you have them just PM me the price . I am in Texas. I would love to have them. Thanks so much.
Dan,
I will pull the column apart tomorrow after work. This evening right after work I had to install a new starter in my buddy's 07 Dodge Ram Cummins 3500 4x4 6.7, and then help my other buddy with fixing the battery terminal ends on his winch battery for the car trailer.
Thanks. No hurry.
![]() Join Date: Mar 2005
Strange, my 70 column was missing those 2 parts also. Never did find them. They weren't there when I took the column apart. I ended up putting in a tilt column, just not super happy with it. Doesn't seem as solid as I think it should. Need someone with a 3d printer to make a run of those parts.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
Wish someone would make them. Still looking.
Did you post a "Want To Buy" in the parts for sale forum? LockDoc
![]() Join Date: Apr 2010
I have a used 39 & 40 I can send you as well, if needed.
72 C10 lwb fleetside -stock 350/350 combo |
Thanks. 70Shortfleet had them. I appreciate everyone's help.
Tags |
upper column |
