09-11-2008, 10:03 AM | #1 |
Anyone running parrallel 4 link?
I want to install parrallel 4 link. Any pros or cons to this setup that I should know? Anyone have pics?
Blazer Project |
09-11-2008, 04:17 PM | #2 |
Re: Anyone running parrallel 4 link?
There's a lot of opinions on what is best, and it just depends on your application and likes. Its great because the pinion angle doesn't change as it moves up and down, but that can create negatives if you are on air and like to drive it at multiple heights. All just a matter of what your doing with it and what your willing to accept and be ok with.
09-11-2008, 04:30 PM | #3 |
I see...Can you be more specific? I will be on air and plant to only have two heights. A few inches off the ground and lying on the frame. I’m just not sure if the position matters. You know, the connection to the frame, adjustment of the bars (length), or anything else. I like it because it seems easier to install than triangulated 4 link. I have other options, like two bars and a wishbone. So I am open to the idea of other types of 4 link, but like i said, this seems easier. Not everything is as it seems though.
Blazer Project |
09-11-2008, 10:21 PM | #4 |
easier maybe but you need a panhard bar with a parallel 4 link. same with most 4-link you need to stay within the set ride height for the best pinion angle...as well as longer bars generally ride better.
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
09-11-2008, 11:26 PM | #5 |
I was going to use a wishbone rather than a panhard (is that okay?). Also, I suppose that I will always have it at ride height except for car shows etc...Correct?
Blazer Project |
09-11-2008, 11:51 PM | #6 |
you mean like a three link (upper links connected)...if so its not needed. if you wanna run a wishbone than use one lower link (per side) and i would mount the bags on the lower link for more lift and a better ride... but a panhard is was easier to setup than a wishbone.
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean Last edited by FnLow69; 09-12-2008 at 12:11 AM. |
09-12-2008, 01:51 AM | #7 |
It'd be alot cooler if you did
a properly set up panhard bar will give you NO troubles. I'm running a parallel four link with a nice long panhard bar and it's fine. I have sleeve bags over the axle and it rides like a Cadillac.
09-12-2008, 10:52 AM | #8 |
Smashing chuck, you have pictures of your setup?
Blazer Project |
09-14-2008, 09:45 PM | #9 |
just snapped these tonight.... |
09-14-2008, 09:56 PM | #10 |
tryin to get laid
Holy big pictures Batman!
Great stuff man, looks good. You runnin boggers on that thing? |
09-14-2008, 11:41 PM | #11 |
09-15-2008, 12:11 AM | #12 |
tryin to get laid
09-15-2008, 12:36 AM | #13 |
"GOD BLESS AMERICA !!!"
My $0.02 : most serious Drag Racers use the 4 Link because of the adjustment will allow you to make it track the way you want it to. Also you can use what is called a watts link in place of the panhard bar. There was a build thread here at one time that had links to a website with a working watts link and 4 link set up.
_ I have a '67 Chevy with trailing arms and I'm thinking of building a watts link to work with my setup. Heres's the place I found for parts: http://www.jegs.com/webapp/wcs/store...FQv7agodMX9AXw http://www.fays2.net/fays2_watts_link_23_.html _ Also I found some stuff at Circle Track Supply that I may end up using. Last edited by 67Cowboy; 09-15-2008 at 12:40 AM. |
09-15-2008, 12:37 AM | #14 |
ART universal. I really like it. |
09-15-2008, 01:20 AM | #15 |
Hey chuck.. you have the web site for that place? Also, its my understanding that the bars should be parallel with the frame at ride height. Are yours?
Blazer Project |
09-14-2008, 10:23 PM | #16 |
100% gearhead
Here's the wishbone I built for the rear of my '62. This would work great for a parallel four link. The middle link to the rear end is telescopic so the axle tracks straight and the suspension can run in it's arc without trying to rip apart the locator and will not travel in a side-to-side arc during suspension travel. Also, if you run the upper bars at a more downward angle to the lower bars accordingly, and depending on the length of all the bars. the pinion angle will stay in perfect relation to the driveshaft.
09-14-2008, 11:51 PM | #17 |
Im gonna have to get me a build thread. Thanks smashingchuck for the pics. Is that a suicidedoor set up?
Blazer Project |
