05-10-2005, 11:52 PM | #1 |
Throttle Return Spring
I was going through the assembly manual and I noticed this pic. I took a look at the piece that holds the coil in and there is a spot on the back that a spring would go to but only if you put the coil holder in backwards. Has anyone seen this piece?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
05-11-2005, 12:02 AM | #2 |
Yes I have 1 of those coil brackets
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
05-11-2005, 12:06 AM | #3 |
There's one on the 307 my Dad bought, are these hard to find?
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
05-11-2005, 12:10 AM | #4 |
Does the coil bracket have the return spring going to it? How is the coil installed? With the screw holding the coil facing the firewall of the intake?
THanks
05-11-2005, 12:16 AM | #5 |
Here is a pic of the coil holder. Does that screw that hold the coil in place face toward the intake or the firewall?
05-11-2005, 12:17 AM | #6 |
Backside of the coil holder. I think that is a carb return spring spot circled in red.
05-11-2005, 01:27 AM | #7 |
The screw side goes toward the front (sort of points toward where the stock window washer jar is located) I pretty sure its slanted like that for improved carb/air cleaner issues. I've never seen the spring tab you have there (cool). I built a bracket for mine out of "L" brackets from the hardware store. Doug
