01-27-2011, 02:10 PM | #1 |
Junior Member
205 transfer case to 4L80E
Will a 205 bolt to a 4L80E? If not the 205 is behind a 4spd now, is there a special adaptor to work with a th400? I am thinking of building a 94-98 c2500 to 4wd using a 79 K20 as a donor (using the tranfer case and front end)
1968 chevelle ss 396 4spd 1969 chevy 4wd 350 4spd 1970 chevy c10 long box 1970 GMC 4wd long box |
01-27-2011, 10:45 PM | #2 |
Re: 205 transfer case to 4L80E
The best place I have seen for adapters is a place called ADVANCED ADAPTERS they sell many types of adapter and conversion kits. Good luck
01-27-2011, 11:29 PM | #3 |
The 4L80E has the same output shaft splines and 6 bolt adapter pattern as a TH400. So if you can find an NP205 that was originally mated to a TH400, Then the adapter and input shaft will fit on the 4L80E.
Dave W. Last edited by 1959 Apache; 01-27-2011 at 11:30 PM. |
01-29-2011, 03:44 PM | #4 |
Correct me if I'm wrong, but isn't the 4L80E longer than the TH400?
01-29-2011, 05:22 PM | #5 |
01-29-2011, 05:28 PM | #6 |
So to put a 4l80E in a 70-87 4x4 model you pretty much have to move the transfer case and transmission mount back about 1.5 inches plus buy the electronic transmission controller too. Seems like a pricey and difficult task to me.
01-29-2011, 03:51 PM | #7 |
1.5 inches move eng foward
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
