![]() Join Date: May 2021
C30 body bushings
Rearend swapped out(set pinion after front is done)..working on front soon. Need to order body bushings (and spring) for front.
I plan to use rubber ones but last checked they were all backordered. Anyone heard if vendors have them yet? Also are the C30s body bushings same as C10/C20?..vaguely recall reading a thread stating C30s were different at the front...either the mount or bushing?
1970 Barracuda slant 6..the one car I wish I never sold! and long ago 1969 C30 CC soon to be 4x4 1980 Boston Whaler Supercat 17sold, 19sold, 20 |
BlahBlahBlah
Re: C30 body bushings
C30 and C20 are the same, not the C10. Went through this when I bought new ones for my C30
You might try Wes at Classic Heartbeat for them, I believe thats where mine came from
Thanks CG..I just went back and checked ..it was the last place I looked.
I emailed HB few weeks ago, no response but I will call them this week. Like to be in line if theres a wait. Their ad didnt specify material type which was all I needed to know. https://www.classicheartbeat.com/pro...eel-bed-floor/
Do you guys know how the C10 bushings differ from C20/30? Or which specific ones are different or the same?
Thank you. |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
https://www.classicparts.com/1967-72...ctinfo/35-146/ They have them...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
The C/10's use the same mounts front and rear with the rear getting a large washer on top and the bolt goes in from the bottom pointing up. The front mounts dont get the large washers and the bolts point down.
^^Thank you
![]() Join Date: Dec 2009
GMCPauls looks like they have them in stock.
https://gmcpauls.com/ Look under Radiator / Cab / Bed Mounts.
