Braide lines off the master cylinder....help please...?
Want to run braided lines of my master cylinder and T up somewhere below the firewall on the frame or close by.
I'm looking for pics here,who sells it and length's. I'm running a CPP master with a 8" booster. I'd appreciate the help. Thank you. ![]()
Always a place in my heart for old Chevy trucks ![]() My build thread-project truck dream 65" http://67-72chevytrucks.com/vboard/s...d.php?t=510863 |
Never Ending Projects
Re: Braide lines off the master cylinder....help please...?
Ideally you should limit flex lines of any type to just the key points on the suspension, for movement. Everything else should be hard line. Too much flex line in the system and it can cause a soft/spongy pedal. Just make up your own hard lines. It's not that hard to do.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#3 | |
Thanks Mike,I was wondering about that.I have only seen lines run this way on the one truck in the pic.Ok for show maybe,but makes good sense not to! Thanks a million. ![]()
![]() Join Date: Jan 2011
You can use lines made for motorcycles and race cars. Can get them with #3 on both ends and open braid or with a clear cover. Keep em short as you can. I use Earls pre-made hoses and they test them to 4000 psi. Used them on both race cars and custom bikes with great results.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
#5 | |
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 03-14-2014 at 03:59 PM. |
Braided liines are fine> Its the same pressure at the MC as it is at the rubber lines. Dennis Kirk sells all kinds of braided lines and fittings. They even have colored lines.
66 shorty ![]() |
Can be done and Should be done are two very different things.
Just saying... YMMV
Senior Enthusiast
The few braided lines I've needed I had custom made by House of Hose in Spokane, WA.
http://spokanehose.com/home Cost has always been roughly 1/3 - 1/2 of what a similar hose costs at Summit, Jegs, etc. Their fittings are also much cheaper than a chain store like Napa. With shipping costs they might not be the best option for everyone, but there may be a custom hose outfit like this in your own community. It might be worth a search before buying out of a catalog.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
We had braided lines made locally with 3AN fittings and ran them straight down to a simple bracket on the frame and transitioned them to hard lines...maybe a bit of a compromise but they work well
1958 Chevy 1 ton dually 4X4 dump/flat bed My build thread 1966 "Not-So-Original" Chevy Custom Trim Suburban My Time-Killing Project Truck 1966 GMC Extended cab 1 1/4 ton 4X4 My Son's build thread |
#10 | |
66 shorty ![]() |
![]() Join Date: Sep 2011
Man that looks so clean, Rock.
Poor and content is Rich...and Rich enough! - William Shakespeare 1966 C10 Custom Cab "Luigi" Big Window - SWB Fleetside 350 V-8 - Powerglide My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894 |
Hi, Ive never seen em run with braided like that, Looks nice,
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438 70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983 76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612 79 GMC 3500 Fleetside LB 454/400 90 Suburban Silverado 4x4 350/700R4 97 1500 Cheyenne Short Fleet 350/5sp |
I'm just glad to be here!
I did mine too. I got the idea from looking at my 2004 Chevy Express van. From the factory they use a section of braided SS line for the flex between the body and frame.
The coils typically in the hard lines are to give the line someplace to flex when the body and frame move in relation to each other. ![]() ![]() I got the lines and fittings needed to do this from Speedway Motors.
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#14 | |
Thank you. ![]()
