Old 09-20-2019, 01:18 PM   #1
elorenzof
3RD brake light issue
Hi all, happy Friday.
I purchased an LED 3rd brake light from Robznob11 and installed it. WORKS GREAT WHEN STOPPING! only if the driver or passenger door is open. ??? wired it into the brake light switch white wire. 1970 c10 2wd. any suggestions?
elorenzof is offline   Reply With Quote
Old 09-20-2019, 01:23 PM   #2
71gmcC15
71gmcC15's Avatar
Re: 3RD brake light issue
Is it grounded though the door swiches? That's my only gess
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original )
94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless
07 gmc sierra classic rcsb 4.3 lt 5 speed w/t
04 chevy Silverado 1500 ext cab 5.3 4l60e.
81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green)
71gmcC15 is offline   Reply With Quote
Old 09-20-2019, 01:55 PM   #3
elorenzof
thank you for your response i gotta check my grounding just like you guys said.
Old 09-20-2019, 02:41 PM   #4
mgkgmc
mgkgmc's Avatar
You could just drive with the doors open just a thought.
1970 GMC 1500 stepside
1972 GMC Jimmy Custom
2004 Chevy Colorado
1989 Swb Silverado
1972 Aj's Stormer
mgkgmc is offline   Reply With Quote
Old 09-20-2019, 03:41 PM   #5
elorenzof
Smile Re: 3RD brake light issue
TEChNICALLY id just have to open the door when i stop
Old 09-20-2019, 09:13 PM   #6
BigBird05
Did you replace the brake pedal switch to a 3 wire? You need a dedicated circuit going to the 3rd brake light.
BigBird05 is offline   Reply With Quote
Old 09-20-2019, 09:43 PM   #7
toolboxchev
Naw, its made that way from the factory so when you go to stop the bird has to fly also!
toolboxchev is offline   Reply With Quote
Old 09-20-2019, 01:24 PM   #8
demian5
demian5's Avatar
If I read this right, for some reason its using the same ground as the courtesy lights. If so, when the doors are closed, there is no ground for the light - that is why. You have to ground the light separate from the courtesy light circuit.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 09-20-2019, 01:55 PM   #9
elorenzof
THANK YOU. I'll pull off the cargo / 3rd light and see where it is grounded and that sounds like you nailed it perfectly.
