01-18-2015, 07:23 PM | #1 |
Flwheel
I am swapping from a 250 six cylinder that has a three speed manual transmission to a 350. Will my existing flywheel work on the 350? If not what flywheel should I search for ?
We make too many wrong mistakes..................Yogi Berra |
01-19-2015, 08:13 AM | #2 |
Re: Flwheel
i did this on a 78 c20 i had to alter the size of the crankshaft mounting bolt holes but it works well
(i cut some steel tube inserts to step the 6 cylinder 9/16 holes down to the 1/2in small block holes and used arp bolts) |
01-19-2015, 08:51 AM | #3 |
Re: Flwheel
I did the same swap and everything bolted right up.
Andrew 1953 3100 292 T5 1985 K5 Blazer 350 700R4 208 |
01-19-2015, 11:33 AM | #4 |
Re: Flwheel
I swaped a 250 six in a 65 panel the 396 was lunched fly wheel off the big block bolted right up. Thats one things that make chevy great.
01-19-2015, 02:57 PM | #5 |
Roadside Rebuilder
Re: Flwheel
Here's a handy reference: http://www.hemmings.com/hmn/stories/...feature29.html
01-19-2015, 04:32 PM | #6 |
Re: Flwheel
I have a 454 flexplate on my 250 six (with the balance weight removed, of course...).
01-20-2015, 09:43 AM | #7 |
Re: Flwheel
'86 and newer one peice rear seal engines changed bolt circle diameter.
