Tire rub need advice!
I just put new wheels and tires on I went with a 295/45/20 in the rear and now it rubs and I cannot take the tires back so I need to know my options? I have a leaf spring rearend that has been lowered...Thanks
Re: Tire rub need advice!
for a solution figure out where it rubs then either move tire away from whats rubbin or move whats bein rubbed away from the tire that's rubbin it
#3 | |
20' Daredevil (Ret)
![]() Join Date: May 2003
![]() Jason, pics would help us... we can't see the problem from here.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
They are rubbing on the outside of the inner fender well I was thinking of making a spacer to go between the leaf springs or grinding some of the inner well out?
What's rubbing? Pics.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Get an adjustable pangard bar and center the differential. I have 295/45/20's in the rear and they are close but no rubbing...
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
#7 | |
Never Ending Projects
My guess is the wrong offset of wheels. Need more info on where it is rubbing. Fender lip, frame, ??? Pics would help too.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
Both sides rubbing?
Redefining LowBudget
place a broom handle on the tire between the tire and body then roll the truck forward it will roll the inner in a bit..you may have to do it couple times
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
Wheels and tires are expensive. Lifting the truck is cheap. That should tell you what I would do.
Ray |
