08-11-2003, 12:14 AM | #1 |
Engine knock found
Well I pulled the engine out of the truck today and tore it apart to find what was knocking. Well the block and everything is trashed. It even distroyed the head. I think that a couple of piston rings broke loose. What do you guys think? Well now the truck will be down for quite some time while I save up the money for a new one.
68 short fleet with 71 front clip 2wd jaguar blue 99 chevy ext cab shrtbed z71 loaded 99 chevy swb fleetside(daily driver) Sparks, Nevada |
08-11-2003, 12:15 AM | #2 |
Pic 2
08-11-2003, 12:22 AM | #3 |
its all about the +6 inches
ouch.
08-11-2003, 12:23 AM | #4 |
PROJECT 7DEUCE
Ouch !!!! When my first motor blew it twisted the rod's and broke the cam.. Do you need a core motor??? I just pulled a runner from my blazer and it need's a new home.
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
08-11-2003, 12:36 AM | #5 |
FRENCHBLUE72--- thanks for the offer. I have one I can use for a core. Besides it will be awhile before I have the money. Things are really tight right now.
08-11-2003, 05:21 AM | #6 |
Designated A-hole!
That is truly ugly!
Sorry dude!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
08-11-2003, 06:08 AM | #7 |
go cyclones
Wow, sorry
08-11-2003, 06:37 AM | #8 |
That sux....happens to the best of us though. Good luck.
08-11-2003, 09:11 AM | #9 |
Any chance of putting duct tape on it to get you down the road? Well it was a thought....I'll help you as much as I can Jim.
08-11-2003, 10:05 AM | #10 |
BUMMER -- YOU CAN HAVE THE 350 4 BOLT OUT OF THAT 69 ELCAMINO FOR $200, & PAY ME WHENEVER YOU CAN.
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
08-11-2003, 10:27 AM | #11 |
Hot Rods For Life
oof.
08-11-2003, 10:44 AM | #12 |
Oh, man!
I feel better about smokey oil burning 327 now. Thanks, I don't think I have enough to whine about now. Looks like time to start over on the engine for you which is what I shoulda done too. I tried a short cut to save money and merely "revived" my 327 with fresh heads (who doesn't like fresh head?) and a new cam etc. The bottom end is now telling me in smoke signals that it needed to be done too. Good luck, just remember, it's only money.
Just remember, everything has two edges. |
08-11-2003, 11:44 AM | #13 |
PROJECT 7DEUCE
AT least you torn it apart before this happened to it .. This was my first motor!!! If rod's are a knockin that em apart before they destroy everything!!!!
08-11-2003, 12:05 PM | #14 |
Congradulations. You now have a brand new boat anchor.
Sorry about that. It happens to all of us at one time or another. At least you can rejoice in the fact that you're not dealing with some new vehicle with a dual overhead cam engine design where you have to be a PhD from NASA to fix it. Good luck.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
08-11-2003, 12:09 PM | #15 |
PROJECT 7DEUCE
Should of put on the attachment huh.
08-11-2003, 05:48 PM | #16 |
Yeah it's a real bummer!!! The block is not even salvageable. So I loaded everything up in the truck and hauled it to work and threw it all in the scrap bin. I figured I'd start from scratch.
08-11-2003, 09:33 PM | #17 |
Not that opinions matter anymore on that motor,but.. the tops of the pistons are intact, which should rule out broken rings migrating to the combustion chamber. It appears more likely that something went down the carb. Any pieces of air cleaner missing? That does bite the big one, when it takes out the block too! Sorry to see it happen.
69 GMC K10 ..some restoration required....still.. |
08-13-2003, 08:58 PM | #18 |
Ouch,That's a textbook example of what happens when all that reciprocating motion gets out of sync. Honestly when you study the laws of physics, and all the various forces involved. I don't know how any of 'em ever stay together.
Over the years, I've heard it called many things such as " The motor , she done blew up" " It came from together" " It had a cast iron fit" " It locked up" " It grenaded " " It shelled out " " It shucked" " It scattered " " It fragged" And my all time favorite: " It done slung all the pewter out of the reachin rods"
"Negative people always seem to have a problem for every solution" |
08-13-2003, 09:58 PM | #19 |
In Virginia...."It blowed up"
Sorry about your engine, if you lived a little closer I could hook you up with a good deal on an L-82. Last edited by Randy70C-10; 08-13-2003 at 10:01 PM. |
08-13-2003, 10:46 PM | #20 |
Not to highjack a thread, but Randy I'd be interested in hearing about that L82...sdelvy55@aol.com
08-13-2003, 10:51 PM | #21 |
Sending PM now.
08-13-2003, 11:03 PM | #22 |
it looks like it started with detonation..then probably loged a piece of the piston in a valve...then all bets are off...were those cast pistons? were all the valves still there? I just "launched" mine too..threw the block away today...i sure would be interested inthat 69 4 bolt elcamino engine
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
08-14-2003, 12:15 AM | #23 |
bigjimzlll >> Yes they were cast pistons. Also part of the valves were broken off too. I need to get with john on that motor. I also have a line on a big block. Choices choices, I have never had a big block truck. JIM
08-14-2003, 12:22 AM | #24 |
My other Love
wow your motor really sh.it the bed, I know how you feel my 454 has a couple of pistons with chunks taken out of them right (done gonna cost me 2500 bucks)
Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
