Cantankerous Geezer
The 47-54 Chevy truck does not fit on any frame without major work. I've heard of some adapting to a S-10 frame, which still requires complete fab of brake and clutch workings. For more info go to www.stovebolt.com
Fred There is no such thing as too much cam...just not enough engine. ![]() |
Fabricate till you "puke"
US bodysource has an article on a glass 47-54 body on an S 10 frame. I have seen a couple bodys mounted on the 73-87 frames(locally), but the track width is a little wide....crazyL
This is not a cheap way to go but is definatly the best rout. Period.
They make sweet frames that your body will bolt up to, but with the newer front suspension etc. You can even get it with a 4link rear end setup! Must be expensive however... www.jimmeyerracing.com Darren
Washington State 1967 Chevy C10 LWB Rodstoration In Progress. 1972 K20 Cheyenne Super |
former desert rat
Location: salt lake city, utah Home of the 3 M's Mormons, methlabs and minivans
Actually, it will fit the full size frame. I have a 1940 Chevy truck with a 75 1/2 ton frame under it. Not too hard to do. You see, from, I think 1935 to about 1980, Chevy truck frames were all the same width. The only difference was where ( and how) the suspension was mounted, and where the body mounts were located. Ive done a ton of these mods over the years. i.e. 1938 Diamond T, 1942 Fedral. A couple of F@rd COE's. All on Chevy chassis. Mind you, the 1/2 and 3/4 ton frames are the same. The 1 tons are just a bit thicker. Good luck
John
94 Chevy Silverado Ext cab 4/6 drop w/ 18's and 2500watt system (work truck). 67 Chevy swb under const. frame off custom, 20's, bagged and a large rat under the hood,and a 1940 Chevy truck under const. |
Old Skool Club
![]() Join Date: Jun 2001
I have a friend who has a '52 on a later chassis (73-up). The track of the tires has the outer edge of the tire tread, a little outside of the fender edge. So, there is about 2-inches of tire sticking to the outside of each fender....with P235-75R15's. I guess it is okay, but it looks kinda hokey to me.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
that was what I noticed also....the track is about 4" wider on the 73-87 trucks as compaired to the old "fatfendered chevs". I think if a guy watches the wheel offset real close, or stretches the fenders........... just thinkin outloud
registered IWATA user
welcome from louisiana, how bout some pics of your truck?
-'63 Ford Fairlane 500 coupe, v8, auto, faded and rusty. awaiting built roller 302 and some flat black -'99 Honda Prelude. vtech/5spd. no pipe, no intake, bone stock. awaiting new top end. -01 GMC Yukon SLT 5.3 dented and scratched with a noisy tranny. Take off that Von Dutch hat before i stab you with a 000 Mack. |
They make bolt on and weld on mustang II style crossmembers for that style truck. That would be the easiest and best looking option IMO. There is good aftermarket support for those models.
rb's obsolete is a street rod company and they make frames for these trucks as well as bolt on front suspension upgrades.
OCB |
