can you still tow with a dropped truck?
here is my dillemma. Im looking for a 55-66 to use for a home depot truck/ towing my soon to be turbocharged 468 nova.
thing is, I dont like the trucks unless they are dropped, have a raked look, and have that general prostreet look. I have enough power and discomfort with the nova, but I still want that general look will I be able to do that and still tow with the car? Im not talking about a crazy drop or anything, maybe 6 inches from stock |
Re: can you still tow with a dropped truck?
if you went with a 2/4 on a 3/4 ton i don't see why not. A 4/6 would be a bit extreme for a tow truck, though. Why exclude 67-72's? They had the option of a BBC, which would match the 468 on your nova, and even if you get a SB truck, it is a little easier to swap in a big block. Just my $.02
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
#3 | |
you have any links to hot prostreet 67-72s that can help sway me? also, which is better for towing, short bed or long bed? |
1961 crewcab
Just put in a set of air bags in the rear in place of the coils, that are rated for the weight you need to tow.
1961 crewcab
contact runninlo here on the board, he has built a dropped truck with air bags that I think they were towing a boat with.
also check out these pics... wrong year , but the idea is there Last edited by jonzcustomshop; 08-26-2008 at 07:19 AM. |
wow, cool pics. THANKS!!!
good to know its doable |
///Relaxed Atmosphere
here is a pick of me pulling my camper. My sub is bagged on 20's.
72 Suburban 64 Chevy short fleet 04 Chevy Colorado Sport Reg Cab 2012 Chevy Avalanche 2003 Chevy S10 Blazer Xtreme http://www.hubgarage.com/mygarage/RA_Jeff 64 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=295915 |
What year is the nova? It would be cool to try to match the years of the truck and the car. A long bed (longer overall truck) is better to tow with. It helps with stability and the whip effect. Its VERY possible to tow with airbags and a lowered truck. In fact if its lowered you better run bags so you can raise it up to go through dips and such.
I personally would try to find a 3/4 ton suburban or panel wagon as close to the same year as the nova. Painted simular too. Of course some people would call me weird I guess.
-61 c10 short step -67 c10 short step -71 k10 long fleet -77 k20 long fleet (gettin all the goodies from frankentruck) -79 c30/k30 3+3 frankentruck (cab and frame for sale) -99 GMC yukon daily driver |
its a 71 nova but I dont want to match years. I want to have a variety.
thank you guys so much for the responses and pictures. very very helpful I have a couple of questions though. am I bagging the front And rear? when bagging does the frame need to be altered? as in a Z frame? and also, how much more space in the engine bay does a 67-72 have over a 55-59/60-66 |
#11 | |
#12 | |
roughly what does it cost to do bags on the rear like you have? |
#13 | |
Firestone 224c (F-6873) air bags @ $75ea CPP 1.5" alum lowering blocks & longer u-bolts @ $69 CPP 'bolt-in' c-notches @ $129 (bolted & welded for towing) owner modified OE shock brackets (the same as a shock relocation kit from CPP or ECE @ $59) Gabriel HD gas shocks (off the shelf stock replacement shocks) 90° air bag fittings $5 (x2) straight 'schrader' fittings $5 (x2) DOT .250" airline $20 from Suicide Doors If you don't go as low you can eliminate the blocks & c-notches. Mine was low enough the rear 'pumpkin' poked a hole through the original wood floor & still towed my trailer loaded w/my 74swb.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 08-28-2008 at 12:16 AM. |
#14 | |
can you recommend a good book on air suspension? |
#15 |
3DrDwn--the 'burb not the band
well it's towed everything in the picture and sometimes 2 at a time.
![]() The Orange one is the workhorse, however the purple truck has towed a car or two itself as well as trailered behind the orange one. ![]() ![]() Blue one has 371k on original motor and has towed and been lowered for most of that. ![]() Josh
Slo and Lo that is the tempo. '72 burb build page here: http://67-72chevytrucks.com/vboard/s...d.php?t=259256 '89 GMC Dually crew build page coming soon. 88 ![]() duallys past/present pics here: http://67-72chevytrucks.com/vboard/s...46#post4001246 89 1 ton Dually rear flip kit install here: http://67-72chevytrucks.com/vboard/s...d.php?t=354327 Last edited by RunninLo; 08-27-2008 at 11:03 PM. |
#16 |
Still Truckless!
As far as engine bay room there are more than a few members on here with big blocks in 60-66's. IIRC the only real pinch points are the headers and maybe some clearance issues with the dizzy. Just make sure to use low profile valve covers. I'm sure at least one of the members with a rat under the hood will pop on here and shed more light for you as needed. Best of luck to you
~James ![]() ![]() 2009 Hyundai Sonata<~~Wife's sedanomatic 1997 Nissan Pickup Father-in-law's tonka toy I am forced to drive ![]() ![]() ![]() ![]() |
#17 |
I tow with my 66. As you can see from the pics, my bud built me a custom hidden hitch which he anchored not only to the rear frame, but also to the the frame closer to the rear end. It tows very well.
[IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]()
http://www.picturetrail.com/fregon |
#18 |
your setup looks awesome.
