Just curious if anyone has had any luck with aftermarket inner fenders ? Do they fight good ??
Re: aftermarket inner fenders
I cant speak of just the inner fenders. I recently built my entire front end using aftermarket panels, I had a lot of alignment issues with the whole clip. I had to trim some off of the backs of each inner fender and drill out some of the spot welds and re-weld them on the front for better alignment. I also trimmed and adjusted all of the other panels. The used hood I got fits well at least.
1961 crewcab
I have a set that worked ok, main problem was that the steering column cover area either had the nuts in the wrong place, or just not there,,, I can't remember which
seems like most problems I have seen mentioned on the board is when people are trying to use an entire aftermarket front clip.. that's where all the fitment issues start... I just used the aftermarket inners, all my other sheet metal is original
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
#4 | |
![]() ![]() Join Date: Aug 2013
Joe |
