Old 01-08-2011, 10:01 AM   #1
tjsblazer
tjsblazer's Avatar
NP205 Yoke question
I have a line on a SM465 / NP205 combo out of a 1976 GMC 3/4 ton 4x4. I want to use it in an earlier 1/2 ton setup. My question is in 1976 did the 3/4 ton have a larger yoke size than the 1/2 ton or were they the same? This particular truck was a 350 small block if it makes any difference. Thanks for any help. Jeff.
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 01-08-2011, 10:07 AM   #2
DetroitDan
DetroitDan's Avatar
Re: NP205 Yoke question
Are you asking if you can use the same driveshaft? Because I know there is a u-joint available that has two large and two small sides to allow that. I put a 3/4 rearend under a half ton and never changed the driveshaft, just used one of those u-joints in the rear.
1982 Chevy K30 CCLB fleetside. Formerly a cab and chassis, now a fleetside dually with the rear wheels tucked underneath. 454/th400/np205/C14/D60, 6/4 inch LIFT, not drop.
DetroitDan is offline   Reply With Quote
