07-15-2014, 11:24 PM | #1 |
Do these cotter pins look right to you
Seems like there's no reason for castle bolts. There are new ball joints and a new ece drop spindles. Should the cotter pins go through the castle bolt or is it fine?
07-15-2014, 11:44 PM | #2 |
Re: Do these cotter pins look right to you
No way id drive it like that. They should go through the castle nut. That is how they are designed.
07-15-2014, 11:48 PM | #3 |
07-16-2014, 12:11 AM | #4 |
Why are the nuts so lower, is because I torqued them when the were jacked up
07-16-2014, 12:25 AM | #5 |
If the nut is lining up with the castle nut. Then there is a big gap between the spindle and ball joint?
07-16-2014, 12:42 AM | #6 |
is it possible to put washers on, or drill a new how for the pins, because the spindles a perfect where there are
07-16-2014, 01:30 AM | #7 |
07-16-2014, 08:12 AM | #8 |
It looks like you have the wrong ball joints for the spindle or the wrong spindle for your ball joints. There are three different ball joints from 63-73, and they all interchange and so do the spindles. I have access to all ball joints and spindles if you need any help, call me with your measurements. 812-631-1182.
Thanks |
07-16-2014, 08:13 AM | #9 |
Proprietor of Dale's Corner
X2 on the wrong ball joints
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
07-16-2014, 08:29 AM | #10 |
Agreed, wrong ball joints for those spindles. When I bought my truck as a "project" the PO had installed all new steering and suspension components. The problem was my ball joints looked like yours. I knew it wasn't right and finally figured out he had put 71-72 ball joints and tie rod ends in 68 spindles. I replaced all that and now everything fits as it should. Those need to be replaced.. don't drive it until you do. Just my .02.
07-16-2014, 08:43 AM | #11 |
For sure the wrong ball joints! Don't drive it
07-16-2014, 09:07 AM | #12 |
Definitely the wrong ball joint/spindle combination. You need to find out for 100% sure which spindle you got - the 67-70 or 71/72. There should be a part number and you can call ECE and ask. Then when you find out which it is, purchase ball joints for that spindle, you'll either get 67-70 or 71/72.
I also keep my old castle nuts. I discovered on my 65 Mustang that the ball joints and tie rod ends, etc that I ordered were all correct and tight for wherever they were tying into, however, especially on the ball joints, the aftermarket castle nuts were 1/8" to 1/4" shorter than the old factory castle nuts causing the cotter pin to have nothing to go through. I reused the factory nuts and all was good. Obviously not your situation here, however, the lower castle nut looks really small for a ball joint, looks more like a tie rod nut.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 07-16-2014 at 09:56 AM. |
07-16-2014, 09:14 AM | #13 |
For sure wrong ones. Get the right ones and start over
07-16-2014, 09:53 AM | #14 |
Forgot to add... the outer tie rod ends are different as well (the one that connects to the spindle)... make sure you have the correct ones... again 67-70 and 71/72 for sizing.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 07-16-2014 at 02:11 PM. |
07-16-2014, 01:17 PM | #15 |
Hey, I want to pile on too! Wrong ball joints! Keep in mind they changed in (1971?) and they are different C10/C20/etc.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
07-16-2014, 03:42 PM | #16 |
So what year ball joints do I need. Any have a link to a good source, I bought ones for a 72 obviously it's not correct
07-16-2014, 04:38 PM | #17 |
You need to look at the spindles and find a part number. Call ECE with that part number, tell them your problem, and verify that you have 67-70 spindles, otherwise you (and us) are just guessing.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
07-16-2014, 04:47 PM | #18 |
07-16-2014, 04:51 PM | #19 |
Awesome! So now you know you have the wrong ball joints. You need ball joints (upper AND lower) AND OUTER tie rod ends for a 1967-1970 GM truck, assuming this is a C10 and not C20.
I have to ask... did you order the lowering kit or "buy it off some guy." I see that your truck is a 71/72 from your avatar pic and it doesn't make sense you have 67-70 spindles when you should have gotten 71/72. If ECE made the mistake, they should trade out the spindles for you.
07-16-2014, 04:53 PM | #20 |
Thanks alot, would these tie rods work. http://m.summitracing.com/parts/mog-es350l. Just don't want to make the same mistake twice
07-16-2014, 04:57 PM | #21 | |
It looks like your truck is a 71/72, this gets a little screwy... if you want to replace your inner tie rod ends, you need to keep those 71/72 to match your 71/72 center drag link bar.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 07-16-2014 at 05:03 PM. |
07-16-2014, 05:01 PM | #22 |
Thanks for your help
07-16-2014, 05:04 PM | #23 |
No problem. I hope you can return the other ones. Ball joints used to be cheap, but they're gotten pretty expensive the past few years.
07-16-2014, 05:42 PM | #24 |
07-16-2014, 06:54 PM | #25 |
Buy the ball joints locally. That way you can pull them out of the box and take a look at them, if they aren't right swap them right then and there for the right ones.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
