Old 10-28-2006, 03:11 PM   #1
ampsyco
radiator hose location
i've got a 70 gmc 1500 2wd pickup. my lower radiator hose sits on the frame. enough to be wearing into it. i got a new hose today and lt looks like the radiator i've got in there might be incorrect. the diameter of the hose is much larger than the diameter of the inlet of the radiator. also it looks like the inlet should be up about 6 or 7 inches from the base of the radiator. mines right at the bottom.
anyone have any pics of their radiator ?? or can someone tell me if their inlet is higher up than right at the bottom ?? mines a manual trans no ac but i dont think that really makes a difference where the hoses are located.
any help would be greatly appreciated.
ampsyco is offline   Reply With Quote
Old 10-28-2006, 05:40 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: radiator hose location
Does your lower neck go straight out, or does it angle up.
The latter is correct.
Old 10-28-2006, 10:21 PM   #3
ampsyco
mine goes straight out. so its supposed to have a bend i guess ???
Old 10-28-2006, 11:06 PM   #4
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
i have had that problem on my 77 as well, i take the old hose and cut out the offending section, cut that like a hot dog bun and wrap it around the new hose at the rub point.
trkklr77 is offline   Reply With Quote
Old 10-29-2006, 07:06 AM   #5
junkyardjohn
junkyardjohn's Avatar
THATS WHAT I DO. ZIP-TIE A 6 OR 8" SECTION OF OLD HOSE OVER THE SPOT THAT RUBS ON THE FRAME. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 10-30-2006, 05:30 PM   #6
TDs6t9
TDs6t9's Avatar
Thank for the idea of the old hose. Just put a new one on this afternoon and wondering about what to do where it hits the frame. Great idea with the old hose. Thanks again!!
TDs6t9 is offline   Reply With Quote
Old 10-28-2006, 10:57 PM   #7
Longhorn Man
yep, you have the wrong rad.
I have installed the rad from a later 73-87 truck, and it sounds like yours has been too, but what I did was cut the lower neck off the old rad, and had the rad shop braze that on replaceing the straight verson.
Old 01-23-2007, 10:11 AM   #8
RShaips
Well , you guys know everything! I was trying to buy a bottom radiator hose yesterday and both places I went had a different hose than I needed. I must also have a newer radiator in mine. The guy I bought mine from had several zip ties wrapped around the hose where it rubs the frame. So I guess I need a hose from a 73-77 truck? I will check today and also buy a larger piece to put on the outside. Thanks
RShaips is offline   Reply With Quote
Old 01-23-2007, 03:56 PM   #9
Longhorn Man
hose from 73 - 87 truck won't help, the frame is still in the way if your lower neck goes straight out.
Old 01-23-2007, 07:40 PM   #10
crazy longhorn
Fabricate till you "puke"
If you have a 73 up waterpump, that lower hose will fit the old truck /with the late (straightneck radiator). mine is setup that way..... However, if you try to stuff that late lower hose on the early waterpump, it will make you crazy (been there , tryed that) L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
