![]() Join Date: Feb 2009
Can anyone describe a kick down assembly?
71 402 C-10 Automatic
They were stock right? Can any describe the factory assembly and how it works? Pics a bonus if possible. Thank you
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
![]() Join Date: Jan 2007
Re: Can anyone describe a kick down assembly?
i'm no expert, but i have a 71 c20 bbc a/t truck sitting in the side yard that's fairly unmolested. here's a couple pics of the switch on the gas pedal...
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
![]() Join Date: Jan 2002
The turbo 400s used an electronic switch to activate the kick down in the transmission. The turbo 350s used a mechanical linkage instead of an electronic switch
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
That explains part of it, thank you. I see those items on my accelerator, which happens to be the next item I'm taking off. Other than the interior wiring, from there it goes to what, the transmission? Mine isn't hooked up.
Perhaps:
Carb. connect? Elect. to transmission? Vacuum?
one of the two wires goes through a firewall grommet and routes down to the trans connecting where shown below. the other wire goes up into a rats nest of wires under the dash (doesn't go through the grommet). that wire looks to be modified. i assume it's supposed to be a hot coming off the fuse block.
Ha ha, one of the benefits of being hump-less. Thanks 68.
I had thought that plug at the transmission was for the transmission controlled spark. Perhaps it's dual purpose? My plug at the transmission has the orange wire from the accelerator, as you stated. That plug includes a black wire as well. The other side of the black was plugged into the unit on the left in this picture (above emergency brake cable). That said, someone did mess with that black wire, because there are two butt connectors. Perhaps the section was damaged at some point. I welcome any corrections, but the relay on the LH (truck side) is the RELAY ASM CONT SW. It's the smaller of the two units. The unit on the RH (truck side) is the RLY ASM TRANS CONT SW DELAY. Both units are for TCS. At least that's my knowledge to this point. Incidentally, if that's all there is to a kick down on a 71, I must have had a power or switch problem. It wasn't working. ![]()
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 12-10-2016 at 12:31 AM. |
Does anyone know where the black wire to the transmission switch comes from, if other than what's described in the above post? I suppose mine could have been rerouted to the TCS relay. That and/or if not plugged into the TCS, which will no longer be installed, I assume the black needs to connect elsewhere. Appreciate any input.
In the meantime, I'll reflect back on the manual. They can be hard to read, but not impossible.
This is what's on my transmission. See Fig. 6 T-27 Turbo Hydra-Matic 400 TCS Connection Terminal Identification
http://www.73spot.com/index_stats_fi...ission/tcs.htm Post #3 is basically my connection at the transmission. His wire doesn't look black to me, though I'm a bit shade blind. http://67-72chevytrucks.com/vboard/s...d.php?t=679916 Post 2, 16 and 24: Obviously the guy has experience. Context can be un- certain.....That's the "beauty" of the web.............http://www.bangshift.com/forum/forum...-switch-wiring Concerning the black wire connected to the transmission. I'm not proficient at reading schematics by any measure, but I believe that's 159D in the assembly manual. It's on a few pages, including 992 for transmission controlled spark (CTS), and I guess that's their way of saying it connects to the trans. on page 993. My 72 402/400TH has just one wire to the transmission, which comes from the pedal assm. Obviously a different plug and transmission switch. It's not working either (go figure). The truck is new to me, but I seem to have lost kick down with the new carburetor install. Couldn't tell you, I didn't put on the carb, but I don't think it had any kick down linkage. The truck did have holes for the TCS relay and relay delay on the firewall, but they sealed them up. Unless someone can advise otherwise, seems the connect at the transmission for a 1971 400TH was dual purpose or rather a mixed bag. Part kick down, part TCS.
