View Poll Results: Does your original, factory air conditioning work?
Yes, it works and blows cold air on hot days 47 40.52%
No, it does not work right now 44 37.93%
No, because I removed it 4 3.45%
No, because this was not a factory air truck or has been updated to modern stuff 21 18.10%
Voters: 116. You may not vote on this poll
Old 01-09-2016, 07:18 PM   #1
davepl
davepl's Avatar
Does your Air Conditioning Work
I thought it'd be interesting to find out what percentage of original factory AC systems are still operating today - and I'm not looking for your "Just needs a recharge" eBay excuses :-) It either works like it's supposed to or doesn't, and I'm curious what the 'kept it working' rate is.
If you've removed it, I put an option there (same deal if a previous owner removed it)
If you don't have air, you don't need to vote, but if you like to anyway, pick Option 4 "Not a factory AC truck"
If you have aftermarket air (ironically often called Vintage like the brand) please pick Option 4, "updated to modern"
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 01-09-2016, 07:28 PM   #2
72MARIO
72MARIO's Avatar
Re: Does your Air Conditioning Work
I voted " because this was not a factory air truck or has been updated to modern stuff"
I installed a old air kit in our 1968 suburban. Should have pieced together a factory kit rather than buying the old air kit. I am far from happy with its performance and it will be removed this year. I bought a 1972 a/c cab to use all the parts from.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-09-2016, 07:30 PM   #3
Grumpy old man
Grumpy old man's Avatar
Where's the box for 260 air ? 2 vent windows at 60 miles an hour
Old 01-09-2016, 07:39 PM   #4
hdff
hdff's Avatar
I pulled mine out a couple of weeks ago. I hope to have it back in and workin within a month. Going back original with R12. Sent the evap fan assembly and the heater box off to get refurbished. Having my original Harrison heater core record.
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach
"Wanda"
Don't argue with idiots, People watching may not be able to tell the difference...
There's someone in my head........But it's not me......
cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394
hdff is offline   Reply With Quote
Old 01-09-2016, 07:58 PM   #5
leddzepp
Moderator
leddzepp's Avatar
It blows snowballs even in 110 degree heat, sitting at a standstill in traffic. Nothing beats a factory AC system with r-12.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 01-09-2016, 08:44 PM   #6
57larry
half of mine is missing. I'm going to install a Vintage Air system
57larry is offline   Reply With Quote
Old 01-10-2016, 12:39 PM   #7
hdff
hdff's Avatar
Heard good and bad about VA, have you thought about getting what your missing and staying stock. Lots of parts on here to be had and you can get most of the parts from a catalog, just my $.02
"Wanda"
Old 01-10-2016, 05:58 PM   #8
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Yes, it works and blows cold air on hot days... The original working A/C in my truck was one of reasons I bought it. I was given some invoices when I bought the truck and one of them shows that in July 2011 the A/C was converted to R134 and the original compressor was replaced with a used original. Last summer was the first year I owned/used the truck and the A/C blew nice and cold.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 01-10-2016, 07:29 PM   #9
greedy geezer
greedy geezer's Avatar
Location: Stoughton MA where everyhing on the road gets rusted out from winter and rock salt
No connection was pulled to compressor when I pug it in the belt squeals and the fuse blows I'll be looking into this further in the spring
greedy geezer is offline   Reply With Quote
Old 01-09-2016, 09:04 PM   #10
mrein3
mrein3's Avatar
I voted yes. My AC isn't original to the non-AC truck but I bought all original parts, modified the firewall to look like an AC cab, adjusted the POA to run r134a, and it blows cold all summer.
FWIW, both of my Chevelles are factory AC cars and both still blow REALLY cold air as they are still both charged with R12. I have to top off the 71 every couple of years but the 72 was last charged in 1989 when I was working my way through college at a local service garage. Sounds impossible but it doesn't get many miles put on it so the system isn't subjected to lots of vibration. It leads a pretty cushy life.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 01-09-2016, 11:10 PM   #11
davepl
davepl's Avatar
I was worried about R-134 not chilling enough, but the discharge pipe frosts right up, so something's cold somewhere. Remains to be seen what it does in 100F temps but in principal the 134 has been good; I do have a replacement condenser that I'm sure is bigger than the old R-12 originals, so maybe that helps.
Old 01-10-2016, 12:56 AM   #12
RustyBucket
RustyBucket's Avatar
The 454 in the Blazer's not factory but the A/C is, blows cold but SQUEALS!!
Neighbor A/C guy says it's a bearing inside the compressor. Haven't bothered to fix it 'cause I never put the top on.
The engine in the '71 GMC is original but the A/C is a kit with a sanden compressor. Blows good and cold
Dad always said, "Son, WISH IN ONE HAND, and ......."
Current toy trucks:
'71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C
'72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt
Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these:
'66 Plymouth Belvedere City of Miami cop car clone.
'70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!!
'67 C10 short/step side mount spare -- SOLD!!
'72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!!
'69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!!
RustyBucket is offline   Reply With Quote
Old 01-10-2016, 01:18 AM   #13
Andy4639
Old member
Andy4639's Avatar
Cool Re: Does your Air Conditioning Work
Mine looks factory and is except for the 134 a Freon and sanderson compressor. All other parts are Chevy are new replacement parts. I'll put my 134 a up against anybodies r12 system anytime.
38* is 38* no matter what!
Mine has performed well now for over 10 years with 134 a.
No I didn't vote.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-10-2016, 11:27 AM   #14
cleanfreak
cleanfreak's Avatar
My 68 has air , not working , original compressor was long gone when I got it , haven't focused the time & funds to fix it , but would like to keep the original components with a new compressor like Andy's
cleanfreak is offline   Reply With Quote
Old 01-12-2016, 12:46 PM   #15
kehstr
kehstr's Avatar
No I didn't vote.
I'm working on doing the same thing, it's a lot cheaper to replace parts, and you can actually buy the refrigerant
kehstr is offline   Reply With Quote
Old 01-11-2016, 12:29 AM   #16
Mine's all there and working but I rarely use it
Old 01-11-2016, 12:34 AM   #17
67ChevyRedneck
67ChevyRedneck's Avatar
Vintage Air been blowing ice cold since 2006. Was a non air truck.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 01-11-2016, 02:51 AM   #18
WorkinLonghorn
WorkinLonghorn's Avatar
I had mine off after an engine swap and a "metal recycler" criminal hopped the fence and stole my compressor and mounts (alone with a collection of vintage power tools and many other tools I used for work).
How hard is it to find small block AC compressor mounting hardware? It was a dealer installed unit with the York type compressor.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 01-11-2016, 09:49 AM   #19
hdff
hdff's Avatar
for a small block you can but them out of a catalog, LMC and others
I think
"Wanda"
Old 01-12-2016, 12:07 PM   #20
cooperhw
cooperhw's Avatar
I think
You are in luck. My 68 came with a 327 that also had a dealer installed York compressor. I pulled the 327 and gave it to a buddy. If you want you can PM me your name and address and I will send the bracket to you. I could include the York compressor but it would add considerable weight to it and you would need to pay for the ride.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 01-12-2016, 12:23 PM   #21
Matt Cramer
Some previous owner had removed a lot of the A/C in mine. Not sure if it had been working at the time or broken.
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 01-12-2016, 02:24 PM   #22
73737373
Of my 6 that start, run, drive etc and have factory AC.....none have a working AC system....waaaahhhhh!!!
1968 Custom SWB, 327/3 speed OTC
1969 CST LWB, 402/400
1970 CST LWB, 402/400
1970 Sierra Grande LWB, 350/350
1971 Cheyenne LWB, 350/350
1972 Cheyenne Super LWB, 402/400
1972 Sierra Grande LWB, 402/400
1979 Silverado LWB, 350/350
1984 Suburban
1990 454 SS
1991 Silverado, X-cab, 4.3/5 speed Getrag
2005 Silverado Crew Cab
Corvettes: 75, 77, 78, 93, 96
73737373 is offline   Reply With Quote
Old 01-13-2016, 09:26 AM   #23
tk1251k
tk1251k's Avatar
My 1972 GMC Sierra Grande works just fine. It has 385,000 miles on it with all original hoses in place and 2nd a/c compressor but other that it works like a charm with no leaks.
tk1251k is offline   Reply With Quote
Old 01-17-2016, 12:32 AM   #24
davischevy
davischevy's Avatar
Don't forget to change the break in oil in the engine.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 01-13-2016, 02:49 PM   #25
davepl
davepl's Avatar
So far it's a perfect 50/50 split between working and non-working on original AC trucks! I am surprised it's actually that high, I figured there would only be a handful that were kep working.
Probably a lot of those in the South I'm going to guess.
