09-12-2009, 03:00 PM | #1 |
67-68 front clip on to a 69-72 truck PARTS LIST
I wrote down all the parts needed to switch your 69-72 truck to a 67-68 front clip. I am going to pick up some fenders and hood (anyone have any experience with their repop fenders and cowl hood?) from ECE this month and decided to make a list including all the small stuff that you would also need.
Obviously you may not need all of it so you can omit whatever it is you do not need. ECE has 20% off till the end of the month for anyone really looking to possibly do this. Radiator support -849250 184.99 Grill Shell -3886762 299.99 Grill Moldings -CX1882 69.99 2 required Grill Molding Nut -G4172 1.99 not sure how many total is needed Rad. Core Mount Set -CX4835 19.99 Grill C. Support Brkt -14105 24.99 LH Grill Brkt -CX1899 24.99 RH Grill Brkt -CX1900 24.99 Headlamp Bezels -CX1228 69.99 Pair H. lamp Bezel Screw -G11591 4.99 8 Required Hlamp Adj Spring -5953168 2.49 2 Required Hlamp Adj set -C1402 4.99 a kit Halogen Hlamps -1149X 39.99 2 required LH Hlamp Mnt BRkt -K892 24.99 RH Hlamp Mnt Brkt -K893 24.99 Hlamp Retning Rings -G7838 46.99 2 Required LH Park lamp Ass -CX1561 49.99 RH Park Lamp ASs -CX1562 49.99 Cowl Hood -T70308 394.99 UnderHood Hrdw Set -SK1013 74.99 LH Hood Hinges -G11598 109.99 RH Hood Hinges -G11599 80.99 Hood Springs -3890741 12.99 2 Required Hood Latch -CX1856 54.99 Hood Bumper Set -K918 5.99 Hood Cowl Set -W9410 9.99 LH Fender 67 -T70111 129.99 RH Fender 67 -T70112 129.99 Front End Bolt Set -K1007 39.99 |
09-12-2009, 03:14 PM | #2 |
Re: 67-68 front clip on to a 69-72 truck PARTS LIST
Have you just thought about buying a 68 and taking the parts you need itll be alot cheaper
70 SWB STEPSIDE 70 BLAZER 09 challenger |
09-12-2009, 03:29 PM | #3 | |
Not to mention then you still have 400 bucks in a cowl hood if your going to go that route. Not to mention risk any clips being broken and such and have to be replaced. |
09-12-2009, 07:04 PM | #4 |
I bought my 68 longbed for $1500 with a near perfect front clip in Orange County CA. I see then once in awhile around here for under $1,500. I also see used 68 front clips every once in awhile and they are usually no more than $500. The original GM stuff will fit better in my experience. Repop body parts are never 100%, usually require some grinding, sanding and fitting ot make them work right.
09-12-2009, 07:26 PM | #5 |
Moderator
I would buy everything you have listed from ECE....except re-pop sheet metal. I would find some original L and R fenders. If you are going with a cowl hood, obviously that would be aftermarket.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul Last edited by leddzepp; 09-12-2009 at 07:27 PM. |
09-13-2009, 04:46 AM | #6 | |
has someone had bad experiences in the past with subpar sheet metal and now wont give it a chance? we have board supporters who swear it is every bit as good as OEM and will use it on their own vehicles. I want the TRUTH!!! |
09-12-2009, 11:00 PM | #7 |
low n' slo
I bought a 67 front clip for 75 bucks here, minus the core support. now, it did have some rust that needs fixing lol. but I got it just for the fender, sold the grille and rest is laying in my back yard. I would give it to ya if u were here near by. so which truck is this going on?
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
09-13-2009, 09:55 AM | #8 |
The metal is great, it's just the fit that leaves a lot to be desired....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
09-26-2009, 12:46 PM | #9 |
one show I watched, they didn't like the EDP coating and stripped a brand-new cab then put epoxy primer. I know that epoxy is the best thing going, but I sort of figured the Electrodeposit Primer was just as good. Any thoughts ???
09-26-2009, 01:39 PM | #10 |
Lemme show you something!!
2 grand for a new front clip! I bought my entire '67 LWB for 800 bucks and my '67 GMC SWB for 1200.....yeah, I got two entire trucks that run and drive well (with good front clips) for what you are about to pay for a just the front end sheet metal.
Truth be known, I have a near perfect OEM front clip minus the trim and hood that I would be willing to part with for way cheaper than the repop stuff you're looking at. The only issue is the shipping, but I'm sure there is a reasonable solution to that.
'67 CST-10 LWB ("Crusty") SOLD '67 GMC SWB ("Murdock") 2000 K1500 Suburban ("Betty") '95 BMW 325i ("Joy") |
09-26-2009, 02:26 PM | #11 |
Classic Chevy Recycler
I bought my 67 Chevy C-20 longbed for $300.
2004 Chevrolet Trailblazer EXT 1970 Chevrolet C50 1979 Chevrolet C30 Need another 67 or 68 soon... |
09-26-2009, 03:20 PM | #12 |
and if people were not buying replacement parts they would not be making them. apparently many more people are buying the parts versus buying used trucks. not to mention new bolts, clips, and what not are included which you would still need on an old truck.
09-26-2009, 04:25 PM | #13 |
I'm just saying that there are options.
10-11-2009, 07:00 PM | #14 |
Dingfodgy,
I'd be interested in the clip. What are you asking? MJH |
10-11-2009, 07:11 PM | #15 |
SWB 4x4 Collector
I understand where you are coming from Vegas, as do many others, but you can literally buy a truck that runs for less than what you have and have all kinds of parts that are GM leftover, so that $400 Cowl Hood could be bought with the leftover money that you make by selling your used parts. Just a suggestion, I know a lot of people buy the repop stuff because they think there isn't going to be a lot of bodywork to get them ready, every panel you find will need something or another though, GM or Repop. I would just think you could actually pocket some money by parting out a truck and getting your parts all in one. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
