Old 01-07-2011, 11:48 PM   #1
cool1972gmc truck
Smile cowl induction hood scoops????
im thinking about putting one on my 1972 gmc truck will something like this work???anyone have some pics of there trucks with one????
http://www.up22.com/scoopw1.htm#SC-113
cool1972gmc truck is offline   Reply With Quote
Old 01-08-2011, 12:02 AM   #2
treveiger
treveiger's Avatar
Re: cowl induction hood scoops????
Like one on each side or one in the middle? If you put it in the middle youll have to cut the scoop to fit over the lip if im not mistaken.
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 01-08-2011, 12:14 AM   #3
cool1972gmc truck
i want to put one scoop in the middle
im not sure how to cut out the middle for the line down the middle of the hood...
Old 01-08-2011, 12:24 AM   #4
68anniversary
They do make cowl steel hoods. I have installed a few fiberglass scoops on a few steel hoods but I don't trust them to not crack later.
68anniversary is offline   Reply With Quote
Old 01-08-2011, 01:32 AM   #5
cool1972gmc truck
68 anniversary i know they make steel hoods but im cheap, do you just rivet it to the hood and then use fiberglass to bond it to the hood???
Old 01-08-2011, 01:36 AM   #6
treveiger
treveiger's Avatar
Maybe try a very sharp razor blade and then fine sand it down, i think itd look funny though when you see it specially when you see the lip going through.
Old 01-08-2011, 02:46 PM   #7
68anniversary
I would go to a place that sells Automotive paints. They have some new panel adhesives that might work. I have used a product called Druraglass as a finisher to blend the edges into the hood. The problem you run into is the hood still is somewhat flexible and vibrations and such cause eventual cracking. Back in the day those scoops were just rivited on drag car hoods.
