06-13-2017, 10:37 AM | #1 |
10 bolt swap Q's
Lost the rear in my '72 Cheyenne. It's a 1/2 ton 2wd. I've got a 10 bolt out of a '99 Suburban I am probably gonna swap in.
Anybody have a part # for a conversion u joint to go from the 1310 style that the 12 uses to the yoke on the 10? Not sure what style the GMT400s used. Also looking for a part # for wheel studs that'll let me go from the metric to 1/2x20. Thanks |
06-13-2017, 11:13 AM | #2 |
Re: 10 bolt swap Q's
I would think with the cost and time it is going to take to get the newer 10 bolt installed you would be better off rebuilding the stock 12 bolt or finding another one. Assuming you have the coil spring rear. You're going to need the trailing arm mounts, panhard bar mount, the coil spring mounts, and the adapters you mentioned. Plus the 12 bolt is a much better rear than the 10 bolt.
06-13-2017, 11:20 AM | #3 | |
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
06-13-2017, 07:48 PM | #4 |
All about them K’s
I don't think they had discs in 99. This is the last year for the suburban in the 88-98 gmt 400 body style. I don't care for the ten my self but to each his own.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
06-14-2017, 11:29 AM | #5 |
06-14-2017, 03:13 PM | #6 |
All about them K’s
Yes that's very true, but his axle came from a 1999... never the less I agree about the ten bolt!
06-13-2017, 12:23 PM | #7 | |
That was a 5 second google search. There's a lot more than just that kit available. The 12 is only better than the 10 if.... You're putting a lot of power to the rear or plan to race. These 10's come behind LS engines and survive just fine for a DD, or mild performance build. |
06-13-2017, 07:55 PM | #8 |
Yep, the Burb was the GMT400 bodystyle- no discs on the 10 bolt.
For the brackets, I would be using the kit that Speedway sells. Just gotta figure out the u joint and wheel studs. |
06-13-2017, 10:53 PM | #9 |
Just wonderin' about the width?
BECAUSE I saw this on C.list today: http://spacecoast.craigslist.org/pts/6107402903.html
Dad always said, "Son, WISH IN ONE HAND, and ......." -------------------------------------- -------------------------------------- Current toy trucks: '71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C '72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these: '66 Plymouth Belvedere City of Miami cop car clone. '70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!! '67 C10 short/step side mount spare -- SOLD!! '72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!! '69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!! |
06-13-2017, 11:48 PM | #10 |
About an inch wider than my stock '72 12 bolt. Be warned.... that most likely isn't a real posi. Probably the G80 GovLoc. People are scared to death of them. LOL
06-14-2017, 08:31 PM | #11 |
I specifically worded my original post to NOT include the word OPINION. If you have one, great. Keep it to yourself. I don't care about how anybody feels about the 10 vs 12 debate. I'm no inexperienced rookie.
I had a thread closed and deleted, and I was put on "probation" (how gay is that? Lol) for getting into it with another member about this swap. So, please- don't screw up my thread w any opinion posts. I'm looking for part numbers, thank you. |
06-14-2017, 09:22 PM | #12 |
Designated A-hole!
Following, because I too have a 99 burb rear end that I'm thinking of putting under my 70.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
06-22-2017, 07:36 PM | #13 |
Well, got the wheel stud problem figured out. Took a bit of research, but I found one that shares identical dimensions with the stock metric wheel stud, but is 1/2x20. Do your own investigating, of course, but this works for my scenario.
Dorman 610-126 Now to decipher the u joint conversion.... |
06-22-2017, 08:19 PM | #14 |
For the u joint measure the cap diameter and width, there are tables of u joint sizes to identify the 10 bolt joint. Let me do search
06-22-2017, 08:20 PM | #15 |
06-22-2017, 08:23 PM | #16 |
I think that site shows conversion joints too. Or type in Google the conversion joint needed such as 1310 to 1350 conversion u joint. They even have the conversion joints at oreillys autozone and rock auto for cheap. Searched those last year for my 72 dart Dana 60 build
06-22-2017, 10:44 PM | #17 |
http://67-72chevytrucks.com/vboard/s...d.php?t=594923
Gonna go tomorrow and look into the Moog/Precision 372. It might be what I'm looking for. |
06-24-2017, 08:07 PM | #18 |
Thanks to a 4 yr old thread & a post by Tx Firefighter, it looks like the u joint needed is indeed the Precision 372.
Now the wild card is whether or not the driveshaft will work as-is. The 12 bolt is still under my truck, so its not easy to get an accurate measurement from the axle tube centerline to the centerline of the yoke thats on it. |
