Old 06-05-2009, 02:32 PM   #1
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Question HEI Setup Question
I bought my HEI distrubitor 2nd hand and all I did was replace the cap, rotor and coil cover. My question is do I have to ground it somehow? I mean I saw in some of the conversion pics that there was a ground wire added to them.
Well mine has a ground wire as shown in this picture and I don't think I need to add one now do I?
Thanks in advance!
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 06-05-2009, 02:41 PM   #2
WorkinLonghorn
WorkinLonghorn's Avatar
Re: HEI Setup Question
That's all mine has. Just make sure the connection is clean with no corrosion etc.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 06-05-2009, 03:06 PM   #3
68gmsee
Active Member
68gmsee's Avatar
It's grounded from that connector through distributor frame and down to the engine block.
On mine, I just made sure that the base where it contacts the block was clean and there was metal to metal contact. I also lightly sanded the bottom of the clamp and polished the threads on the bolt to the engine block. Not sure you need to do all that though.
68gmsee is offline   Reply With Quote
Old 06-05-2009, 05:30 PM   #4
C20-67_N_MO
Okay cool then I am covered then.
Thanks guys!
Old 06-05-2009, 05:38 PM   #5
cparman
sharp as a marble
in your picture, there are 3 tangs, that get connected to the wiring from the distributor, and from your 12v+ source. The center one is a ground strap that is between the coil and the distributor cap. This is the ground for your distributor.
cparman is offline   Reply With Quote
Old 06-06-2009, 05:47 AM   #6
jim zag
ENGINE BUILDER
jim zag's Avatar
You should be good to GO!
JIM ZAG
jim zag is offline   Reply With Quote
