Plastic door hinge bushings???
Has anyone ever seen plastic door bushings or was the PO a cheapskate? I found these when I was BEATING the pins out of my hinges. No wonder the doors were sagging...
![]() ![]() They almost look like an electrical component that I have always known as Red Devels, or MC Flex Bushings. like these Anyone else seen this?
1969 ![]() 2015 GMC 2500 Duramax (Daily Driver) 1999 Jeep TJ 2010 Harley Street Glide Check Out My Build!: http://67-72chevytrucks.com/vboard/s...d.php?t=617981 |
Re: Plastic door hinge bushings???
That's definitely a cheap fix! I don't know how many things I had to fix on my truck that were awful attempts at repairs. Some of them look like they took more money and time than just purchasing the correct part would have been.
Those aren't worth a turd as door bushings.
Brad handshoe |
Quick fix to sell the truck at one time i bet.. No matter how well you look it over, you cant catch sh t like that!!
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold ![]() 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
I'm pretty sure plastic bushings were oe equipment.
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
Never heard or seen that. Interesting. Not disputing it, but would be curious to see more comments. All ive seen were brass i believe. Maybe the plastic was OE replacements?
![]() Join Date: Dec 2011
Hmmm.... Who knew! Thanks for the replies guys.
Photographic evidence.
Folks that throw dirt on you aren't always trying to hurt you, and folks that pull you out of a jam aren't always trying to help you. |
guys i find it odd that plastic/nylon was used also.
but i gotta say this, "most" of the ones i pulled were usually not in too bad of shape after all those years. also i think perhaps they could get a tighter hinge pressing the pin into the plastic since it will expand or give some. the bronze/metal type of bushing wont give to much before it will crack or shatter learned this the hard way. i also had to sleeve a hinge once.the long hole in the hinge was pretty wallowed out so i drilled it oversized round again and i used some tubeing and sliced it lenghtwise until it was tight in the hinge and pin. that hinge worked really well and is still tight today.
All about them K’s
![]() Join Date: Jun 2014
My dads k20 had a set plastic bushings in one of the doors.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Back when I was rebuilding hinges for people, I saw about half and half plastic vs bronze on original hinges. The new replacements are bronze.
Well, there ya go. Learn something all the time. I bet those plastic ones come apart easier...
Thx for clariying ![]()
Pulled mine out of my 67 C10 today; starting door refurb. Can't believe how good of shape they were in. No cracks just score marks in the plastic. No slop in the door neither. Surprised me!
#15 |
What is the chosen method of removing the pins from the hinge?
#16 |
![]() Join Date: Mar 2015
Every original hinge I have pulled apart had the plastic bushing installed. They seem to last for decades and they cost less than brass or bronze. That’s why you can rest assured GM used them. On the heavier and longer door like on a Camaro they didn't last long.
greenweenie your originals are some of best I have ever observed. Amazing or they have been replaced? However, the pins look 100% original. New bushings and you're golden. I wouldn’t replace the pins on your hinges. Almost all the replacement are designed for multiple years and the replacement pin is too long. Getting them out is another ordeal. Almost everyone I rebuild needs to be heated to get the pin out. And typically, it's red hot and the plastic bushing melt. They are difficult to get into a press as they will roll without a fixture. Even then it's easy to bend an ear if the pins sticks. A big vise and a 4Lb hammer seem to work the best. I hit the pin a couple times and if it doesn't move, out comes the torch. A small hammer will just pein the end over so best to make it a BFH. I drill a small divot in the top of each hinge half, on the side the pin is flared. This will avoid confusion when resembling the hinge. Cheers |
