Hey how many wireharness clips are on the Lh frame rail on a 72 Blazer? The ones that both the fuel sending and rear lighting wires clip in to.
Also, does anyone have pics of where they go. I can't seem to find a drawing in the Assembly manual. Thanks. Jeff.
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
Re: Wireharness clips on the Frame question
There was 3 of them that I pulled off mine
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612 Build version 2.0: 72 K5 6.0 LQ9, 4L80e, NP205 http://67-72chevytrucks.com/vboard/s...d.php?t=793192 ____________________________________________ 1972 CST K5 Blazer Dark Olive |
Here are a couple pics from mine:
72 Ochre Blazer 69 Camaro Z28 Garnet Red 48 Willys (rolled) |
One more:
Not sure if these pics will help, but I took these before I took the frame apart.
Edit; Oops, I just realized it was wiring clips you were concerned about and not brake line clips. Those are the only pics I had, sorry. |
Maybe someone can actually find the page in the assembly manual, I can'y
#7 | ||
I actually had 7 total and 2 of them were along the rear x-member for the Fuel sending wire. That would leave 5 along the frame rail if I had them all.
Thanks. That helps with a few of them. Quote:
Hopefully someone chimes in who has a survivor truck that has the factory clips still in place.
Actually Minnz you've shown 4 different ones on your pics. Mine had 5 remaining along the side when I took it apart if that was all of them there is only one more spot. Don't know if my Bkazer still had them all or not.
is this it?
![]() It measures .575 from front of assembly manual
#10 | |
Jeff, it says except for G&I-X
Ok, I found another pic of a 5th clip. It was located above the driver's rear spring shackle:
Well that may be it. Like I said mine had 7 total with 2 being on the back x-member. Maybe 5 is correct for down the frame rail. My truck was fairly stock except for a 4"lift. I'm going to use your pictures Minnz as reference for now. Thank you.
