Original longbed or cut shortbed?
So here is my truck the day I got it.I traded a 95 Nissan truck for it.I drove it for a while then over heated it.So I decided to do a complete tear down and shortbed conversion.
![]() ![]() ![]() I got the truck to this point,then I got a running 72 burb as a wedding gift from my boss and his wife.So When that happened I decided I wanted a 4x4. ![]() I started looking on craigslist for 4x4 brackets & crossmembers to convert my frame to a 4x4.I came across a 67-72 4x4 frame with all the the brackets.I asked the guy If he would be interested in a trading the 4x4 frame for a shortbed rolling chassis.I told him that I shortened it and at first he said he wasn’t interested but I emailed him a link to my build thread and he changed his mind.I got the truck stripped down about an hour before the guy got here. ![]() I ended out trading my chassis and trans for a 4x4 frame with all the brackets,350 trans and np205 transfer case,steering box,6 lug rear end to match the dana 44 I got a few weeks ago and 2 original 6 lug steel rims.I still need a few things to make a complete 4x4,but Im really happy with the trade. ![]() ![]() ![]() I made a cab dolly out of an old frame that was damaged. ![]() ![]() pat Last edited by pat english; 12-21-2014 at 01:39 PM. |
Moderator
![]() Join Date: May 2007
Re: Original longbed or cut shortbed?
Cut the frame
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
![]() Join Date: Mar 2003
If that's what you want cut it. Sounds like you have the skills. Shortening a frame or lengthening to me is almost second nature. I wouldn't hesistate
![]() Join Date: Nov 2004
Cut it. It's what YOU WANT.
Shortbed 4x4's are rare... like REALLY rare... it would be cool to see more of them around. Just please don't ever try to pass it off as a real shortbed 4x4 and I think most people would be cool with it. I'm converting my truck from a short step to a short fleet and it's actually pissed a few people off, which is hilarious because it's my truck, it's what I want to do with it! ![]()
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#5 | |
You asked for opinions and here's mine,a 4x4 is and meant to be used as a truck IMHO. And if it's meant to be used as a truck it might as well have a full size usable bed. Now if your building a 4x4 that isn't going to see any off-road or truck duties then it's a no brainer if a shorty is what you prefer.
#7 | |
#8 | |
Don't take my comment to mean that your opinion is wrong. I'm just saying that there are other perspectives on what a truck can be used for and which one is best for which type of use. |
#9 | |
If you are going to do any towing with it I say leave it a long bed. If not build it either way. Both long and short beds look good as a 4x4.
68 4wd Stepside 69 2wd Stepside Project 71 2wd Blazer Project 72 2wd 3/4 Ton Project or Parts? 73 4wd Blazer |
#13 | |
I tow a 4000 pound boat with my short bed fairly often with no problems...plus backing is easier with the shorter truck.
1972 Cheyene C-10 "Ole Green" My Grandfathers truck (early 70's to 1983) My first vehicle (1983) Original 350 (3 rebuilds) 700R4 from Bowtie Overdrives ![]() |
Cut that frame if you want a short bed!
#15 |
Mine's not a 4x4 but it was a long bed , I cut mine down and don't regret it but if it were a 4x4 I'm not sure I'd want it cut down. Leave it long for now and see how you like it, you can always cut her down later, Keep the short bed make it a trailer paint it to match your truck, if you decide to cut it down you'll have it ready to install and a place for your long bed to go.
#16 | |
if i could find some long step bed sides that would be cool.longbed stepside 4x4 would be cool. |
#17 |
Right on guys.Thanks for all the responses.I thought about it long enough i guess.I'm going to shorten it then.I like the shortbed and my wife does too.she remembers when i had a longbed frame in the garage and it was tuff to get through.Those longbed stepside bedsides are just too expensive and too hard to find used.
would anyone know which trans crossmember i have?is that for the turbo 350? |
#18 | |
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
#19 |
![]() Join Date: May 2003
The cross member goes under the transfer case adapter, and if it originally had an NP205 on it then it can be used for either a T350 or a standard, with an NP205. The cross members were the same.
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
#20 |
nice.So its the 2wd that had the different trans crossmembers.
#21 |
Cool thanks.So if i want to switch to the sm465 trans i will need a different adaptor?
#22 |
You'll need a different adpt and the transfer case would have to be from behind a sm465, or the in-put shaft would need to be changed. Autos & standards had different spline counts.
#23 |
Whaat about the engine crossmember?do big block 454's fit in there?i read somewhere that they didnt do a bigblock 4x4 but ive seen people with them.do they use aftermarket crossmembers?
#24 |
maybe ill just use what i have for now.unless i come across someone wanting an automatic 4x4.
#25 |
The auto set-ups are a bit more desirable and harder to find. You should have no problem selling or trading with someone. You could sell the auto adpter for $100 or more itself.
