Lurky lurky
Removing Tailgate latch
My tailgate latch is binding, so the gate won't stay up. I want to take it off, but the screws are refusing, I have tried the biggest screwdriver in my box, an electric drill, a pneumatic drill, basically everything short of stripping the freakin' thing. I guess after 3-4 paint jobs it's just stubborn. Any advise or ideas?
Re: Removing Tailgate latch
You can drill them out.We've had to do that at times. Also you may try one of those impact screw drivers. it works sometimes
pick the screw driver that gets the best bite on the screw and has a good solid handle. Put it on the screw, push down and turn slightly to the left, then give it a couple good licks with a hammer, not hard enough to bend the sheet metal of course. Poor mans version of impact screw driver, its been known to work.
67-72 Addict!
You could try leaving the gate down and soaked in penetrating oil first all day. Might help.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
PB BLASTER then impact screwdriver
what happened to flint mi
i used an impact screwdriver , knocked em rite off , took all of 30 seconds for all three
71 swb 2wd fleet frame off in progress 72 4x4 blazer daily driver 70 olds cutlass s mint condition owned by a grandma 56 gmc 2wd project waitng 97 fiance mobile |
Take an old screw driver that fits tight. Cut the end of it off. Weld it to an old socket. Take your air impact (you do have one don't you) and go forward first . Then remove them. Works "most" of the time.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
