03-13-2005, 03:25 PM | #1 |
Front clip removal method
I'm getting ready to pull the body off the frame on my '57 truck. First will be the front clip. Does anyone have a list of the things that need to be done to remove the front clip? I think that once the front fenders/front clip are off, removing the cab should be pretty straight forward, but I'd appreciate any pointers on that too.
Thanks, John.
1957 3800 flatbead |
03-14-2005, 07:39 PM | #2 |
Clunker Farm, Proprietor
Let's see... You should be able to handle this job with the following tools and supplies:
OK, off the top of my head and assuming that you are taking the front end sheet metal all together with the radiator...
The cab is easy enough to remove. However, it is a LOT heavier with everything attached (doors, glass, etc.). To free the cab...
BTW, it's easier to pull the cab if you get the bed out of the way first. What did I miss?
Drew Chief Junk Jockey Last edited by Norselander; 03-14-2005 at 07:50 PM. |
03-15-2005, 11:46 AM | #3 |
Wow, great information. The truck has a flatbed, which I don't intend to remove unless I have to. I'm transplanting the cab and fenders onto a 1985 suburban frame, and will build an all-new flatbed on that frame. Here's the truck:
Here's the frame (with 6.2L diesel engine ) suburban frame And, here's my lovely assistant Alisa (this is going to be her truck when she gets her license). Thanks for the help, John.
03-15-2005, 12:22 PM | #4 |
That sounds like quite an undertaking. But it looks as though you have some nice sheetmetal with which to work.
Drew Chief Junk Jockey |
04-10-2005, 01:25 AM | #5 |
Cute kid...but I'd put her in the Mack
I contemplated a similar swap for my '59...to an '85 4x4 witha 6.2 diesel...the '85 has such a great ride for a 4x4 straight axle, plus..how many times do you see a diesel TF truck? |
