12-21-2003, 06:53 AM | #1 |
Life is a gamble
Rusted Bolts
I purchased my first truck today and I'm having trouble removing some of the bolts on the step side fenders. I've been soaking them with WD-40. Does anyone know of other products or ways to get these off?
12-21-2003, 08:47 AM | #2 |
We use a product called "Aero Kroil" that works very well but you may have to heat the nuts up to get them to move if soaking does not work.
We also have a driver that we got from Sears. It will accept Phillips bits and when you hit it, it rotates to loosen. This keeps the bolt head from stripping out. The driver works very well. Torching the nuts off is a last resort. Good luck! JIm |
12-21-2003, 09:58 AM | #3 |
Designated A-hole!
PB Blaster works for me.
Post some pics of your truck!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
12-21-2003, 11:09 AM | #4 |
Getting the small bolts loosened on thing s like beds, bed sides, bed fronts, etc. can take more time and effort then it's worth. A quick and simple solution seems to be to put a good ratchet on them (either air or manual) and tighten them till they break off. Don't even try to loosen them!!! Takes a turn or two and your done. Go to Tractor supply and buy replacement bolts/nuts by the pound.
12-21-2003, 11:38 AM | #5 |
PB Blaster works great! I don't use WD40 any more. Spray it, give it a little time and they will back right out.
Bill - Tucson, AZ 47 Chevrolet 2 dr sedan 56 Chevrolet 210 2 dr sedan 66 Chevrolet Malibu 2 dr 4 speed 71 Chevrolet C30 Longhorn 86 Chevrolet Monte Carlo SS (Sold) 01 Chevrolet Tahoe IM - BUSTERWIVE@aol.com |
12-21-2003, 12:26 PM | #6 |
Robert Olson Transport
i used to swear by liquid wrench til i got a can of pb blaster
getting rusted nuts off i f that dont work i use a dremel with a cutoff wheel
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
12-21-2003, 04:45 PM | #7 |
Resident Curmudgeon
Smoke wrench AKA Oxy/Acetelyne torch. Heat your nuts until cherry read (the ones on the truck). Works every time
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
12-21-2003, 08:01 PM | #8 |
Next!
If it will reach, buy a cobalt bit, drill through the head, or drill the side of the nut, and split it off. The dremel method also works.
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
12-21-2003, 10:38 PM | #9 |
Formerly yellow72custom
I've had good luck with PB Blaster and heat......even a cheap burnz-o-matic torch will help removing stuck bolts. Just heat the nut.
And also use a "cheater bar" (piece of pipe placed over the wrench for more leveraage) and you can get most bolts out. If all else fails, grind them off
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
