94 frame under a 63 gmc
Well got lots of work done the past week . Did lots of research about this and everyone said don't but I had too. After finding the donor truck with new tranny and new clutch and motor that only has 10000 kms on it the battle began . It was not as tough as most would think worked out really good to Me.
Re: 94 frame under a 63 gmc
Looks good, might have to pop over and take a look.
Did you shorten the box too?
And, is that the cab I saw in your garage this summer? I still need to grab those bezels for my stepside. |
Ya that's the cab and yes I shorting the box but it's in real bad shape and found a couple different set I found
The stepside box will look good on there.
Looks good man glad it worked out for you!!!!
Looks good. So what all did you have to do to make it work? I have been thinking about doing the same.
Well the cab fit well plan on moving the front mounts back and shorting then by 1 1/4". The rear hole end up right over top of the frame ,have some work to do there. Rad support is about 4" off the frMe going to make custom mounts or use part of the 94 rad support to mine so I can use stock location. It's not as hard or bad as I thought it would have been. Going to post more pictures and info as I get more done this weekend
#10 | |
did any of the hole(s) line up or what kind of modification(s) needed to be on to settle the component(s) on that late model frame .... ???
dont want to hear excuses, i want to hear solution(s) |
![]() ![]() Join Date: Jul 2002
Very Interesting. Can't wait to hear more on this!
Can you lower that frame and suspension easily?
Make any progress on the weekend? |
Ya can get stuff way easier and got the cab mounts all finished up will get some pictures up tomorrow
#15 |
Pics?
#16 |
got some pitures front mounts are off the new frame just cut down and moved back. rear mounts are off the 63 frame just cut down to match angle and welded on top of the frame. im working on the rad mounts right now igoing to use the rad support off the 94 and cut it down to mount the 63 to it.
#17 |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Any updates?
#18 |
![]() Join Date: Jan 2011
He last logged in more than 2 years ago. Be nice to know if it ever got finished.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
#19 |
4 years later bump.
Sure wish you'd post how it all came together.
