06-10-2009, 04:16 PM | #1 |
Another trans swap question
I am hoping to get around to swapping a 350/700R4 combo from my 86 burb donor into my 74 SWB within the next few weeks.
I am wondering if anyone can tell me what all wires I would need to keep in order to use the stock computer to control the trans functions? Got a diagram maybe? I don't really have the money to buy anything from the aftermarket for it at this time, and I need to get this thing going.
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r http://67-72chevytrucks.com/vboard/s...d.php?t=460030 97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver 220,000 miles, all stock for now |
06-12-2009, 04:23 PM | #2 |
Re: Another trans swap question
Do I just need to keep the wires that run to the trans, plus the power and ground wires? Will that work? Or should I just wait until I can afford an aftermarket solution?
06-13-2009, 11:38 AM | #3 | |
http://www.tciauto.com/Products/Inst...76600_inst.htm Internal trany wiring is straight forward, but you need a replacement switch (GM part number is provided) and can be easily duplicated. Externally a brake switch and a vacuum switch can be wired for TC lock up function. //RF
"The Beast" 1975 Chevrolet C20 longbed 350/700R4! with 3inch body lift Dual Flowmasters Super 40's! TBI retrofit completed (2007-07-29) New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17) |
06-12-2009, 04:31 PM | #4 |
subscribing to this... anyone??
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
06-13-2009, 06:59 AM | #5 |
dang its hot
aftermarket is the best for this application..TCI makes a good one
06-15-2009, 03:49 PM | #6 |
Thanks for the link.
Another reason I asked if I could do it with the stock ecm was that the guy I got the donor vehicle from is a friend of mine and said the trans only has about 3000mi on it, and I don't really want to pull the pan off.
