09-18-2010, 10:50 PM | #1 |
GobbleStalker Calls
Rear end help.
I just found out my truck is not posi and has 3.07 gears. I want ot make it a posi and am pretty sure I will want to change the gears to 3.55 ot 3.73's. What is the spline on these trucks. Can I put a 12 bolt camero gears and posi in or will they not match up?
Thanks Kev |
09-19-2010, 02:33 AM | #2 |
Re: Rear end help.
The 12 bolt car R&P can not be used in the truck rear. You will need gears made specifically for the truck. The truck shafts (65-up) have 30 splines.
http://tomsdifferentials.com/catalog.asp?pg=10 Ray |
09-19-2010, 06:32 AM | #3 |
Six in a row makes it go...
Re: Rear end help.
Have you ever set-up a rear before? Setting the pinion depth usually requires special tools...
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
09-19-2010, 08:49 AM | #4 |
Re: Rear end help.
if you buy the parts//posi,gears,bearings shims seals etc it's right around the $800mark
to me investing that much money it's worth the extra to have it installed by a pro for the few extra hundred another option is to look for a 40year old junkyard piece and take your chances with a well worn $300-$400 piece
09-19-2010, 09:35 AM | #5 | |
Re: Rear end help.
Once again, cdowns is on it. "Pay a Professional"
Setting up a rear end is a very precise thing. It has to be done exactly right or it will fail quickly.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
09-19-2010, 03:21 PM | #6 |
GobbleStalker Calls
Re: Rear end help.
I would not be doing htis myself. Beyond my capabilities. Thanks
Kev |
09-19-2010, 03:30 PM | #7 |
Re: Rear end help.
Well then - raycow is right, you can't use car parts in the truck rears. There's plenty of truck 12-bolt gears and posi carriers available.
09-19-2010, 10:24 PM | #8 |
Re: Rear end help.
I'm going to make a wild guess...350 turbo..307 rear..60-62 MPH Maybe some where around 5500-5900 rpm?
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
09-19-2010, 10:39 PM | #9 |
Re: Rear end help.
my truck 350 motor,turbo 350,3.07 gears at 60mph = 2000 rpm. i had a 66 chevelle 396,4speed,373 gears at 60mph =3000 rpm.
09-20-2010, 12:49 AM | #10 |
Re: Rear end help.
If your gong with all new stuff, go with a 3.42 gear set and good differential.
Also like it has been previously said, let a pro put the rear end together.You will save money in the long run. |
09-20-2010, 03:49 PM | #11 |
Re: Rear end help.
I like this compromise if you're gonna go with the TH350.
09-20-2010, 02:29 AM | #12 |
Re: Rear end help.
Oscar '72 Shortbed Fleetside '95 Jimmy 4X4 '69 GMC Custom Camper |
09-20-2010, 08:30 AM | #13 |
Re: Rear end help.
My 350/TH350/3.73 combo with 28" tires runs about 3300 at 65. 3.07 gears are more highway friendly. I say go with the 3.42 gear and have a compromise of 3.73 and 3.07 gears.
