10-18-2013, 09:43 AM | #1 |
Ordering Bedsides: Stake Pockets vs. No Stake Pocket Hole
I'm placing an order from Mar-K for some new bedsides today, and I'm stuck on whether I should order the original version or the version with the pockets capped.
What's the advantage of not having stake pocket holes? Is it purely aesthetic? Does it substantially prevent corrosion? Any insight would be appreciated. |
10-18-2013, 09:49 AM | #2 |
Re: Ordering Bedsides: Stake Pockets vs. No Stake Pocket Hole
Looks only.
10-18-2013, 11:27 AM | #3 |
I got mine without the holes. Mar-k makes a nice product!
10-19-2013, 08:35 PM | #4 |
Made my own bedsides...no stake holes. Just depends on how you want it to look. Any water running into the stake hole would just run right out of the bottom of the pocket.
My build http://67-72chevytrucks.com/vboard/s...d.php?t=495795 |
10-20-2013, 09:44 PM | #5 | |
I chose to keep my stake pocket holes, so I can use them for sideboards. But, to keep this rust problem from reoccurring I redesigned my rear cross sill so that the stake pockets now drain straight down.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
10-20-2013, 08:11 AM | #6 |
I've always had trucks with the original bed side panels, and never used the stake holes for anything.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
10-20-2013, 11:22 AM | #7 |
The stake holes in any pickup bed are there to put side racks in to haul something like a big load of firewood or a load of pumpkins to market.
Most of us who customize our trucks remove them anyhow so if it's a custom I'd go without and if it is to be a restored or pretty close to restored rig I'd go with the stake pockets to keep that showroom stock look.
10-21-2013, 11:28 AM | #8 |
Thanks guys. I kept them just in case I decide to use them for something down the road. I figured I can modify the bottoms of the pockets if I felt like they don't drain adequately.
10-21-2013, 12:09 PM | #9 | |
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
