Old 06-28-2003, 11:01 PM   #1
70shortnphat
"See the U.S.A....."
70shortnphat's Avatar
A/C and heater vacuum lines?
Does someone have a diagram of the vacuum connections for a 70 with factory A/C? I'm working on getting my A/C going and none of the vacuum lines are conected to anything. It was like this since I bought the truck. Im replacing the evaporater with one that has the oriface in the inlet. I got it out of an 87 Oldsmobile station wagon. It bolts right in to our trucks. Someone can have my old evap, expansion, manifold hose for free if they want it. dont know if any good or not.
1970 short bed fleetside
1949 all origional chevy 3600
1974 camaro
Richmond , Texas(just S.W.of Houston)
70shortnphat is offline   Reply With Quote
Old 06-28-2003, 11:03 PM   #2
70shortnphat
Hear is the evap going in
fits perfect.
1974 camaro
Old 06-29-2003, 04:29 PM   #3
70shortnphat
ttt
1974 camaro
Old 06-30-2003, 12:46 AM   #4
jef5150
Inline 69
jef5150's Avatar
is this what you want??????
if you need some thing else ,let me know.I have the whole service manual for 1970
jef5150 is offline   Reply With Quote
Old 06-30-2003, 01:31 AM   #5
krue
Designated A-hole!
krue's Avatar
I think he might be talking about the control vacuum lines.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 06-30-2003, 11:51 AM   #6
cableguy0
just some words of adivce go get a new accumulator and dont use that one you have laying there that accumulator is trash once they are exposed to open air they suck the moisture out of the air and become filled to capacity rendering them useless in an a/c system
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 06-30-2003, 06:23 PM   #7
70shortnphat
Thanks jef5150 but I need the vacuum control hoses locations.
Like on the back of the control head.
1974 camaro
Old 06-30-2003, 06:23 PM   #8
70shortnphat
and the heater control valve.
1974 camaro
Old 06-30-2003, 06:24 PM   #9
70shortnphat
and at the right kick panel.
1974 camaro
Old 06-30-2003, 06:25 PM   #10
70shortnphat
and the pasenger side cowl.
1974 camaro
Old 06-30-2003, 06:39 PM   #11
Wreck
#1 will go to the water valve
#2 goes to a "T" that one side goes to the vacuum reservior and the other goes to the pass door
#3 will go to the outside vent.
I know the pic is small but it helped me when did the vacuum lines.
Wreck is offline   Reply With Quote
Old 06-30-2003, 06:41 PM   #12
Wreck
or if your switch only has two vacuum outlets..then use this diagram
Old 06-30-2003, 06:41 PM   #13
70shortnphat
the top of the vacuumcontrol head moves. what atatches to it to move it?
1974 camaro
Old 06-30-2003, 06:46 PM   #14
Wreck
mine had the 3 vacuum outlet and nothing was atatched to the top of the control head, It is all controlled by the position of the levers frum underneath it...not sure about if on a 2 outlet control head.
Old 06-30-2003, 06:52 PM   #15
70shortnphat
Mine has two and it looks like a cable should attatch to the top part and make it pivot. it turns very easily 360 degrees.
1974 camaro
Old 06-30-2003, 07:00 PM   #16
Wreck
Does that control head have anything connected underneath it?...not sure If I can help with that type, but after you figure it out, that vac diagram will help you the rest of the way.
Old 06-30-2003, 07:10 PM   #17
70shortnphat
no nothing underneath. and nothing was connected on top either.
nothing connected at all since I bought the truck.
1974 camaro
Old 06-30-2003, 07:24 PM   #18
jef5150
Inline 69
jef5150's Avatar
hope these work ,,,
i have no idea how these are gonna turn out ,i had to compress them 5 times before i was aloud to send them!!!!
Old 06-30-2003, 07:28 PM   #19
jef5150
Inline 69
jef5150's Avatar
kinda fuzzy
another 1
Old 06-30-2003, 08:23 PM   #20
EdB
There is some good info in these posts and I
sure saved it.
Thanks,
EdB
EdB is offline   Reply With Quote
Old 06-30-2003, 09:29 PM   #21
70shortnphat
Thanks for all the help "jef5150" and "wreck."
1974 camaro
