Old 10-20-2003, 10:17 AM   #1
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Gas gauge wont hold still
My gas gauge needle moves back and forth from 3/4 to 1/4 while i'm driveing. I'm thinking sender unit ? anybody else have this problem? Who sells a good replacement?
Its driveing me nuts
Steve
1970 CST Short Wide
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2019 GMC Diesil Dually. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 10-20-2003, 10:45 AM   #2
landon4421
Life is Good !
landon4421's Avatar
I had the same problum ! Never really figured out what it was ! I changed the sending unit and the wire and the gauge stoped bouncing around ! A month later I tore the truck down, so all I know is it worked for that long ! Good Luck !
'72 Chevy C10 4x4 shortbed "Project"
'71 Chevy C10 2wd longbed "partsrunner"
'91 Chevy Burb 4x4 "kidrunner"
'14 Honda Accord Sport "commuter"
landon4421 is offline   Reply With Quote
Old 10-20-2003, 10:49 AM   #3
Ackattack
Ackattack's Avatar
I got a new sending unit from LMC.
It sounds like you may not be getting a good ground.
Ackattack is offline   Reply With Quote
Old 10-20-2003, 11:15 AM   #4
1970 CST Short Wide
Senior Moment
As I suspected. I'll be cheching for a good ground and look for a good replacement sender.
Pittsburg Ca
94565
Old 10-20-2003, 11:54 AM   #5
mikej71
Unregistered User
mikej71's Avatar
I have the same problem, but it only started after I replaced my instrument cluster bezel. I'm sure it's a ground issue, but I'm not sure where the cluster is supposed to be grounded to the dash.
Can somebody tell me where the ground is supposed to be connected? I don't know why I didn't note this when I pulled it out...
Mike
71 SWB Stepside
SB400/TH350
mikej71 is offline   Reply With Quote
Old 10-20-2003, 12:12 PM   #6
Solver
Solver's Avatar
I had the same problem I think with my 71. The gas needle would flucuate back and forth when driving. I put in a different gas gauge and the problem went away
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 10-20-2003, 02:40 PM   #7
A.P.
Black 72 Chevy
A.P.'s Avatar
Grounding as others said. Check them.
72 Chevy, SWB, 350engine, TH400
A.P. is offline   Reply With Quote
Old 10-20-2003, 03:48 PM   #8
landon4421
Life is Good !
landon4421's Avatar
I had a ground issue with my dash also, mikej71 ! I just ran a wire from the back of the bezel and conected to the cab !
Hope this helps ! Landon
Old 10-20-2003, 05:39 PM   #9
SWEET7T
Try spinnin 4 rear tars
SWEET7T's Avatar
I just assumed it was from gas sloshing around in the tank...
When I turn a corner it moves up and down as the gas moves to one side or the other. It stays pretty still when going straight.
SWEET7T
1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB
SWEET7T is offline   Reply With Quote
Old 10-20-2003, 08:42 PM   #10
mikej71
Unregistered User
mikej71's Avatar
Thanks Landon. I've tried attaching a wire from the metal housing to a screw that's in the bottom of my dash, but I guess i'll just try moving it around to different places.
Mike
71 SWB Stepside
SB400/TH350
