Old 06-02-2013, 09:40 PM   #1
71'4wdK10
71'4wdK10's Avatar
Need help with correct wheels?!
I have a 71' K10 LWB truck, with lockers and Dana 44 front end. Im trying to go back stock on almost everything. Does anyone have a image of what Chevrolet put on the 4wd trucks... Rallys with hub cut outs? Juicer style, ???, i.e. Please post pics of direct me in the correct way. The truck has black wheels, chrome bands, and 73-88 style hubcaps?!? Thanks Brothers
71'4wdK10 is offline   Reply With Quote
Old 06-02-2013, 10:35 PM   #2
70cst
70cst's Avatar
Re: Need help with correct wheels?!
http://67-72chevytrucks.com/vboard/s...d.php?t=449588
Check the above LINK and maybe you might get the correct pics that you are looking for.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 06-02-2013, 10:48 PM   #3
70cst
70cst's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=494812
Look at entry #13
http://67-72chevytrucks.com/vboard/s...d.php?t=505450
http://67-72chevytrucks.com/vboard/s...d.php?t=578281
I hopes this helps until you get some other pics
Old 06-02-2013, 11:02 PM   #4
jocko
jocko's Avatar
trim rings were not factory (post #13 in the link).
Wheels:
Standard: 6 lug 15x6" steelies
Optional: 6 lug 15x8.25" steelies
(note: Truck rallies were NOT a factory option in 71 or 72).
Caps/wheel covers:
Standard: White hub caps (blue bow tie) (didn't have any pics of these, but identical to bright ones shown below, just white where these are bright...)
Optional: RPO PO3 Bright hub caps (blue bow tie) (note - the 2nd ochre/white truck has 73+ yellow bow-ties on it below, but they can be repainted to blue)
Optional: PRO PO1 Bright wheel covers
All front caps/wheel covers would have had the cutout for the Dana 44 lockouts. I'm not 100% certain the wheel covers were yet available in 71, but know they were in 72.
Tires:
Standard: G78-15
Optional: H78-15
Optional: L78-15
Here's some pics:
Old 06-02-2013, 11:11 PM   #5
jocko
jocko's Avatar
as for wheel color - I believe they would have normally been white, regardless of truck color. BUT, that is something I'm not 100% certain on - I have seen a restored truck or two, and a few original brochures (69 sales, for example) that showed black wheels (with NO caps).
Here's the 71 brochure - shows white wheels on the blue K20.
Old 06-02-2013, 11:40 PM   #6
SS Tim
SS Tim's Avatar
Then of course there were the 10.00-16.5C tires on 8.25" wheels. Big bump from the stock 15x6" wheels and G78-B15 tires. As an interesting note, these cost more than the A/C option!
The K10 pickup wheels were white, 67-68 4x4 trucks had black wheels without caps.
SS Tim is offline   Reply With Quote
Old 06-03-2013, 07:42 AM   #7
6 x 15 was standard
8.25 x 16.5 option w/10.00s
16" was also an option,but can't recall if they were 6" or 5.5"
8 x 15s (not 8.25) were aftermarket,then factory later on
No hubcaps till '69
Pre-69 had black wheels
'69 had silver
Post-69 had white
The wheels you need were used through '91
Old 06-05-2013, 09:11 PM   #8
71'4wdK10
71'4wdK10's Avatar
IF i cant find hubcaps you guys think i should just run white steel wheels.. Trucks going back Medium (Hawian Blue) THANKS SOOO MUCH FOR THE HELP!! ITs GREAT!
Old 06-05-2013, 09:21 PM   #9
jocko
jocko's Avatar
personally, I would do exactly that until you find some. runnin w/o caps looks good, was stock in earlier years. but keep up the hunt, they pop up fairly often. are you looking for po3 hubcaps or po1 wheel covers?
