04-16-2016, 05:21 PM | #1 |
59 Apache gas tank
Looking for a EFI gas tank I would love to keep my tank behind the seat ? I'm trying to find something on a budget used or new . I've read slot of older forums but just looking for info on what people are using today
Posted via Mobile Device |
04-16-2016, 07:28 PM | #2 |
Re: 59 Apache gas tank
with the tank behind the seat you may experience a warmer cab. depending on which system you use, unused fuel from injection goes back to tank warmed up from going through the system. you may want to rethink the warm fuel behind your butt theory. just saying. up to you in the end.
04-16-2016, 09:38 PM | #3 |
Hollister Road Co.
It would be noisy, EFI pumps do make noise and it would be a constant hum behind you getting outer as the fuel dropped, that and having high pressure fuel behind the seat would be scary for me.
04-16-2016, 11:39 PM | #4 |
Any body know if I could find s tank for around $350 or is anybody selling a used one
04-17-2016, 01:05 AM | #5 |
Hollister Road Co.
I don't know of anyone making EFI tanks for behind the seat. You would have to retro fit a pump and pump hanger for it. You could use an external EFI pump and plumb in under the floor, that way you keep the stock tank. You would have to use a corvette filter/regulator so you not end up with a return to the tank. You should be able to do that for under the $350
04-17-2016, 01:40 PM | #6 |
Can you send links on the stuff I would need. thanks I appreciate all the feed back
04-17-2016, 03:12 PM | #7 |
Hollister Road Co.
04-17-2016, 03:20 PM | #8 |
It's a 5.7 350 vortec its stock I believe it's 250 horsepower
04-17-2016, 04:36 PM | #9 |
Hollister Road Co.
04-18-2016, 01:43 PM | #10 |
why not use the stock tank and frame mounted pump with a return line going into the gas filler neck?
if you existing tank is in good condition and you want a behind the seat tank, the oem tank is your only option
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
04-18-2016, 01:46 PM | #11 |
You might try the marine world for an alternative option. Marine apps sometimes use a reservoir connected to the mechanical engine pump. The reservoir has a float which prevents overfilling by the mechanical pump, and a high pressure pump to circulate fuel through the fuel injectors and back to the reservoir. I used one in my '67 Chevelle for several years.
04-18-2016, 07:54 PM | #12 |
I'll check into that style thanks
