Old 08-05-2007, 06:53 PM   #1
xshadow
can anyone Id this engine?
on the front pad it reads v0119twt
on the rear of the engine block it has 3970010
and a 36 near the same area.
I may be wrong but I was gitting information from somone that said it was a 350 out of a c30-3500??? I think he said a 1977? Can i find out if it's a 4bolt main according to these numbers? Or what year it is.
were is the number on the heads? thanks
xshadow is offline   Reply With Quote
Old 08-05-2007, 07:23 PM   #2
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Re: can anyone Id this engine?
TWT 1977 350 fwrd cab L LS9 165 4 C-30 & 3500
350 - 4 Barl out of a C-30 big truck, 165 Horse Power
4 Bolt ??? no way to know w/o pulling the pan
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 08-05-2007, 07:44 PM   #3
xshadow
what is a fwrd cab? thanks for the help
Old 08-05-2007, 08:45 PM   #4
Ricks1971
Ricks1971's Avatar
http://www.mortec.com/castnum.htm
looks like from the casting numbers it can be several things gotta drop the pan to tell.
Ricks1971 is offline   Reply With Quote
Old 08-05-2007, 08:48 PM   #5
1968SWBBigBlock
Active Member
I have no idea what the fwrd cab refers to.
They list conv cab, van, bus and fwrd cab under the "applications" area.
I would guess it refers to the type of chassis it was delivered with.
1968 SWB
Old 08-05-2007, 09:57 PM   #6
xshadow
I see what your talking about rick but when combined with the number on the front of the engine it would be a 1977. that would eliminate all but the 350. Do you guys know what the 36 would be for? it is located near the rear casting number
