Old 11-30-2013, 01:32 AM   #1
runpasthefence
runpasthefence's Avatar
AD Rear Bed Crossmember - Pictures?
So, I'm piecing together an AD bed. I didn't get a bed with the truck, so I could use a hand on some reassembly.
The rearmost bed crossmember I bought has no predrilled holes. Before I go all willy-nilly with my drill, does anyone have any pictures of that crossmember installed?
I'm guessing the bedsides rest completely on top of of the crossmember, and they also butt completely up against the sides?
runpasthefence is offline   Reply With Quote
Old 11-30-2013, 02:20 AM   #2
Donaldo
Re: AD Rear Bed Crossmember - Pictures?
I believe that from '47 to early '51 they were 9 boards wide, mid '51 and up are 8 boards wide - surely makes a difference on where the board mounting holes go -
Donaldo is offline   Reply With Quote
Old 11-30-2013, 03:03 PM   #3
gale
You don't say what year. I can only tell you about '54 to '87 but if you see a picture this assembled it's going to fool you. The rear crossmember goes into the stake pocket. There are bolts through the stake pocket to hold the rear crossmember but there is also a vertical weld. If you are familiar with welding this appears to be 'down hand' with an E7014 rod. This leaves a concave or 'washed out' thin weld without much structural value but we're connecting sheet metal. I cut these two welds out with a cutoff wheel on a die grinder.
I have a '54 and a '67 bed completely in pieces for painting. The rear cross members are 55 1/4" wide while the bed is only 50" inside. I can send you a detailed drawing for hole placement but I don't think a picture will help. Can you send a photo of what you have?
Gale Gorman
'54 3100
'67 C20 stepside
gale is offline   Reply With Quote
Old 11-30-2013, 08:34 PM   #4
vht
Mark K or 1 of them had pictures and instructions on their site.
vht is offline   Reply With Quote
