05-27-2010, 09:59 PM | #1 |
"something witty here"
starter problem?
when I hit the key it turns over for a split second then stops and makes a whining noise, I had tested it before I put it in and it worked well. is it broken or am I?
57 chevy 4x4 70 swb fleetside 4x4 68 burb 2wd: 71 burb 2wd: 350 4spd 71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear 72 lwb fleetside Cheyenne 454/th400 1991 GMC V3500 CC 4x4 |
05-27-2010, 10:08 PM | #2 |
Re: starter problem?
have you checked your flywheel for missing teeth?
or the clearance may be a little loose
1970 C10 Fleetside longbed 350/TH350 |
05-27-2010, 10:46 PM | #3 |
Yea I looked at the fly wheel and its fine, its funny to say but it kinda makes a vroom noise lol. my dad said something was effed in the starter but thought Id ask here
57 chevy 4x4 70 swb fleetside 4x4 68 burb 2wd: 71 burb 2wd: 350 4spd 71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear 72 lwb fleetside Cheyenne 454/th400 1991 GMC V3500 CC 4x4 Last edited by Wildstreak; 05-27-2010 at 10:47 PM. Reason: whoops |
05-28-2010, 12:23 AM | #4 |
is your wires good? maybe its arcing somewhere where you are loosing volts and it wont turn the starter fully
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
05-28-2010, 01:46 AM | #5 |
Sounds like the pinion gear is spinning but not popping out to engage the flexplate/flywheel. I would pull the starter and test it by putting battery cables on it. Make sure that the pinion gear pops out and spins fast. If not, it's bad.
05-28-2010, 06:29 AM | #6 |
Bad starter drive. The pinion is engaging the flywheel, but the overrun clutch in the drive is slipping.
Ray Last edited by raycow; 05-28-2010 at 06:31 AM. |
05-28-2010, 08:08 AM | #7 |
i'd spray the heck out of the nose of the starter with wd40 to make sure the shart is clean allowing full engagment
05-28-2010, 01:21 PM | #8 |
I had tested before installing with battery cables in a vise, it engaged fine. Im sure its like raycow says, now is it rebuild-able or should I just buy a new one?
05-28-2010, 04:09 PM | #9 |
I agree it's like Raycow say's. Buy a new starter drive & put in on the armature & you will have it fixed. They are available rebuilt but are not very good. It's not worth the difference.
