700r4 pan leak
I cannot get the pan/gasket to seal on my 700r4. I have gone through 2 OE pans and 3 gaskets. It's been suggested that I try an aluminum pan and/or a rubber gasket with steel inlay. Can anyone attest to using either of those? If so where did you get them? Thanks
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
![]() Join Date: Jun 2009
Re: 700r4 pan leak
I have a 3 quart aluminum 700r4 pan for sale. Send me a PM if interested. It wasn't leaking when I pulled it so that might be a good sign.
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
![]() Join Date: Oct 2011
Re: 700r4 pan leak
Double check the seal for the TV cable. Seen alot of those leak and mask themselves as a pan gasket leak. Also check the seal for the fill tube....
Re: 700r4 pan leak
Agree with abeamn7. Also check the o ring around the selector shaft, and pull the converter shield off and look for wetness, pump seals sometimes disguise themselves as pan leaks too.
Another possibility, my pan gasket leaks but only after sitting for several months, the converter drains back and over fills the case. |
#5 | |
Re: 700r4 pan leak
