250 valve cover clips
I'm getting a 250 valve cover ready for paint and was wondering if the clips on the side of the cover are necessary? If so what do they hold? Sorry it's my first time doing one of these and I didn't take pictures when we turn I apart. There's four on the drivers side and 3 on the other. Thanks
![]() Join Date: Nov 2006
Re: 250 valve cover clips
they hold part of the wiring harness
I BELIEVE IN JOHN 3:16 |
![]() Join Date: Feb 2002
Also held the stock vacuum line wrapping around from the alternator on the passenger side to the carb on the drivers side. I think it was aluminum 1/8'' tubing. Possibly even the stock steel 5/16'' fuel line, if I can remember that far back.
The wires from the bulkhead connector to the Coil and Alternator were clipped on the passenger side. [Plus water temp gauge line and elec oil pressure idiot light.] If your oil pressure warning light went on -- it meant you were screwed.
Thanks guys. I left them on.
Before you paint the valve cover, you could bend the tabs out. Then after the paint has dried, you could dip them in Plasti-Dip before you bend them back on your wiring harness to soften the edges so they don't cut into the insulation. The factory did some kind of rubberizing on the tabs. Usually it comes off when the sheet tin is hot tanked and/or bead-blasted.
Plasti-Dip comes in many colors, but probably not Chevy Engine Orange. [Assuming that's your color of choice.]
http://m.ebay.com/itm/272417394522
There is usually clips like these wrapped into the harness that clip into the holes around the valve cover. I have re-used them and put back. The ones I have seen up into the square body trucks are black, longer and thinner. I have never seen the tabs bent over the harness
-Cody |
Plastidip isn't a bad idea for the clips. I'll probably use some rubber hose cut lengthwise to cover them. Then again I could just wrap the wires with with something where they lay in the clips.
Posted via Mobile Device |
I have nicked an ungloved finger on them once or twice -- they can get sharp. Just sayin'.
I am a Referee of life.
I use shrink wrap on them. Heat, then trim.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
